> Building Porsche 914 in Europe with some mods, Modified engine, wiring, interior - new project
Pyetookh
post Nov 21 2025, 07:19 AM
Region Association: Europe
Hello all,
I was on historic motorcycles for years but was waiting for the right moment to switch to classic car instead. I was also searching classifieds for several years choosing the right classic car to buy. The main contenders were BMW 2002 and Porsche 914.
Unfinished project Porsche 914 appeared for sale not far away from my place some half a year ago. So I went there to have a look. Due to the personality of the seller and obvious intention to sell cheaply we agreed on buying price. Project is 75% finished and there are plenty of spare parts (He had a donor car). But some parts are missing too.
1. The main issue here is absolutely no history! The car was restored by professional car mechanic who died and all his pictures, notes, paperwork, receipts, documents are lost, stolen and missing.
2. My other problem is that I´m Central Europe based and my German is poor. So my only source of information is this forum in US. There doesn´t seem to be such enthusiastic fan base of 914s in Germany and it´s not much economical to order work and parts in Northern America for me.
3. I´m brave enough to do any welding or assembly jobs on my car but I don´t have much experience and I´m not very handy.
Despite all this I would be REALLY thankful if I get any support from well experienced guys here because I have all the commitment to bring another Porsche 914 back to the road.
This build will be for modified Porsche 914 – I would like to upgrade certain parts but rules for historic cars are stupidly strict in my country
I will really appreciate your help with the following:
1. There is 2.0 refurbished T2 bus engine in the car. That will be removed and sold as it is. From all the spare parts I have I would like to build 2056cc engine using my 1.7 crankcase and 1.8 heads (will need to source 2.0 crankshaft and rods, the right camshaft, 40 Webbers, 96 cylinders and pistons).
2. Car electrics – One is in the car but seems to be a bit messy. I have a complete spare one but it´s far from being perfect. I would like to remove FI wiring and add central locking, electric windows, DLR, intermittent wipers, electric windscreen washer
3. Car body is sound and recently resprayed. But I don´t like the colour and the rear wheel arches. Therefore it will be converted to GT flares, will be lowered and go on 16” 205/225 wheels. I would like to weld some reinforcement into the tub.
4. Car interior will need to be done from scratch – All the door window and targa roof trim and seals is missing. I want more like Sheel sport seats. Dashboard to be assembled. Foot pedals to be assembled and connected. New carpets installed.
5. I search for reliable and cheap European parts suppliers
So this is my mission and this is my carAttached ImageAttached ImageAttached Image Attached Image
Thank you and have a great day everyone
bkrantz
post Dec 1 2025, 08:36 PM
Let me add my welcome. Your car looks like a great starting point. I endorse your strategy for a resto-mod with some new features that you want. You should build the car the way you like.
A couple of suggestions:
For the wiring harness you can certainly add to it for other features. And in the engine compartment, most of the fuel injection wiring is a separate harness and easy to leave out. I suggest you lay out the original main harness on a big table, label every connection (and check them). And then carefully plan all additional wires--but spend enough time planning so it comes out correct. Then wrap the revised harness so it looks like the original.
For 100 hp, I can't advise on a 1.7 or 1.8, but my intuition tells me it can be done. I have only owned 914s with 2.0 motors, either stock or enhanced. My current 2056 (96 mm pistons and cylinders, custom heads, camshaft, twin body FI and electronic ignition, higher compression ratio, etc.) makes 125 hp on a dynamometer.
By the way, I am a real fan of CZ firearms. Between my son and me we own 3 rifles and I just ordered another.
Pyetookh
post Dec 2 2025, 12:37 AM
QUOTE(bkrantz @ Dec 2 2025, 02:36 AM) *
Greetings to Colorado and thank you for your support (IMG:style_emoticons/default/wink.gif)
Yes. FI harness is seperate and easily removable.
I have a complete spare harness which I´m going to rework on the table as you suggested. Then it will replace the one inside my car. That will be some challenge.
Just wondering if someone has already tried to make his own modified wiring diagram to make it a bit easier for me. Are there any modern voltage regulators or other parts worth replacing to make the electrics more reliable?
Your engine is serious piece of kit. Must be fun to drive such car. (IMG:style_emoticons/default/driving.gif)
I spent some time reading a few forums last night to collect info on 1.8 big bore builds. Got only very vague information that it can be done but you need to take into account some extra heat, find the right cam, count compression ratio and shim cylinders etc. Someone recommended not to exceed 8.5:1 CR. And that was it. No more details.
I thinking to go for these:
original 66mm crank and rods
1.8L heads
1.7L crankcase (code W)
barrels https://www.design911.com/p/cylinder-kit--b...ource=doofinder
pistons https://www.design911.com/p/piston-set--fla...ource=doofinder
IDF 40 Webbers
Don´t know what cam to choose
What do you think, folks? Can such setup provide any good powerplant?
I like there is a little link between Colorado and Czech Republic (IMG:style_emoticons/default/gunner.gif) (IMG:style_emoticons/default/biggrin.gif) I´ve never been to Colorado but visited Colorado River at least some 10 years ago (IMG:style_emoticons/default/wink.gif)
bkrantz
post Dec 2 2025, 08:22 PM
QUOTE(Pyetookh @ Dec 1 2025, 11:37 PM) *
1.8L heads
IDF 40 Webbers
You need to get the color version of the wiring schematic diagram for your year car. Somebody on 914 World has a link to a page with most of the schematics. You can consider a modern voltage regulator and some LED light bulbs.
Sorry I can't advise you on the 1.8 build, but others on the site can--right guys?
chmillman
post Dec 3 2025, 07:59 AM
QUOTE(bkrantz @ Dec 3 2025, 03:22 AM) *
Anyone have a color diagram for a non-USA ‘73 or ‘74? All I have found are USA ones and the Euro model wiring is somewhat different.
Pyetookh
post Dec 18 2025, 12:59 AM
Gentlemen, can anyone give more information from my ID plate, please? I only know this is 1971 1.7L. There are no other plates or labels on my car and it´s repainted in black.
Thank you
chmillman
post Dec 18 2025, 01:29 AM
QUOTE(Pyetookh @ Dec 18 2025, 07:59 AM) *
Thank you
It would be helpful to have the body number... Normally on a "Karmann" plate on the drivers side forward door jamb, which also has the original color number. If you say that plate is missing, you might also find the body number stamped into the sheet metal of the floor of the rear trunk under the carpet. It's not extremely visible, here's what mine looks like:
The body number can be decoded to find the date of maunfacture. Otherwise, with the complete VIN number (including the last numbers blacked out), maybe one of the historians can provide more info.
Pyetookh
post Dec 18 2025, 06:21 AM
QUOTE(chmillman @ Dec 18 2025, 07:29 AM) *
Thank you
Fantastic! Thank you for your reply.
Yes. Unfortunately "Karmann" plate is gone. But I´ll try to locate the stamped body number.
I´m very sorry, wasn´t sure if posting full VIN number is a good practice here.
Here´s my full VIN if "historians" can do their magic.
Pyetookh   Building Porsche 914 in Europe with some mods   Nov 21 2025, 07:19 AM
mepstein   :wttc:   Nov 21 2025, 07:40 AM
Shivers   :wttc: Congratulations. I can’t help with Euro...   Nov 21 2025, 08:00 AM
didenpx   Greetings to Czechia!   Nov 21 2025, 08:24 AM
chmillman   My other problem is that I´m Central Europe bas...   Nov 21 2025, 08:51 AM
Cairo94507   :wttc: Welcome to the World. It looks like you ar...   Nov 21 2025, 09:18 AM
Pyetookh   :wttc: Welcome to the World. It looks like you a...   Nov 23 2025, 09:22 AM
Superhawk996   :wttc: This one will be a fun one to watch it com...   Nov 21 2025, 10:09 AM
Puebloswatcop   :wttc:   Nov 23 2025, 09:28 AM
Pyetookh   :thumbsup3d: Thank you for all the welcomes and su...   Nov 23 2025, 09:47 AM
Pyetookh   Gentlemen, can someone advise me how to get around...   Dec 1 2025, 05:33 AM
bkrantz   Let me add my welcome. Your car looks like a grea...   Dec 1 2025, 08:36 PM
Pyetookh   Let me add my welcome. Your car looks like a gre...   Dec 2 2025, 12:37 AM
bkrantz   Let me add my welcome. Your car looks like a gr...   Dec 2 2025, 08:22 PM
chmillman   You need to get the color version of the wiring ...   Dec 3 2025, 07:59 AM
Pyetookh   Gentlemen, can anyone give more information from m...   Dec 18 2025, 12:59 AM
chmillman   Gentlemen, can anyone give more information from ...   Dec 18 2025, 01:29 AM
Pyetookh   [quote name='Pyetookh' post='3237275' date='Dec 1...   Dec 18 2025, 06:21 AM
Pyetookh   [quote name='chmillman' post='3237278' date='Dec ...   Dec 18 2025, 02:03 PM
krazykonrad   :wttc:   Dec 2 2025, 02:37 PM
Shivers   You might want to look into having some work don...   Dec 2 2025, 06:24 PM
rick 918-S   :wttc: :sawzall: :smash: :welder:   Dec 18 2025, 06:28 AM
chmillman   Is that 1129586? If so: Body number decode: 1129...   Dec 18 2025, 02:08 PM
wonkipop   Is that 1129586? If so: Body number decode: 112...   Dec 18 2025, 03:01 PM
chmillman   If so: Body number decode: 1129586 First numbe...   Dec 18 2025, 03:19 PM
wonkipop   If so: Body number decode: 1129586 First numb...   Dec 18 2025, 07:53 PM
Pyetookh   [quote name='chmillman' post='3237353' date='Dec ...   Dec 19 2025, 12:04 AM
SO.O.C914er   :wttc: This is awesome keep it going. You will enj...   Dec 18 2025, 08:44 PM
chmillman   Doing a search in the 914World VIN database: 4712...   Dec 19 2025, 02:40 AM
Pyetookh   And the winner is ....... Mr. chmillman :cheer: ...   Dec 19 2025, 11:29 AM
chmillman   Cool! OK, so I assume my original decode is c...   Dec 19 2025, 11:45 AM
Pyetookh   Cool! OK, so I assume my original decode is ...   Dec 19 2025, 02:36 PM
Pyetookh   Funny enough L13K is listed only for 1974 but my c...   Dec 19 2025, 02:50 PM
chmillman   Yeah, that is odd. L13K is also listed for 73, bu...   Dec 19 2025, 03:10 PM
JeffBowlsby   Lets figure out your model year. Does your front ...   Dec 19 2025, 04:41 PM
Pyetookh   Lets figure out your model year. Does your front...   Dec 20 2025, 09:15 AM
chmillman   You need to lift the trunk floorboard to see what...   Dec 20 2025, 10:15 AM
Pyetookh   Very sorry. Wrong picture. No brace there   Dec 20 2025, 12:09 PM
burton73   @Pyetookh Sorry that I missed this, but I have ...   Dec 20 2025, 12:59 PM
wonkipop   @chmillman has better eyes than me. good thing i ...   Dec 21 2025, 04:58 PM
Pyetookh   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Jan 5 2026, 03:55 AM
chmillman   Yeah, I would have a tendency to agree, nothing re...   Dec 22 2025, 03:47 PM
Pyetookh   Yeah, I would have a tendency to agree, nothing r...   Jan 30 2026, 12:21 AM
Front yard mechanic   Just fill in the wrong numbers with bondo and blam...   Dec 22 2025, 04:17 PM
wonkipop   if both those cars, the 71 and the 73 (burnt) are ...   Jan 5 2026, 04:27 PM
Pyetookh   if both those cars, the 71 and the 73 (burnt) are...   Jan 6 2026, 12:33 AM
Pyetookh   It´s time to tackle my wiring and car body. Wiri...   Jan 14 2026, 12:58 AM
Pyetookh   This is how I would like my car to look. White o...   Jan 27 2026, 12:54 AM
flipb   This is how I would like my car to look. White or...   Jan 27 2026, 08:52 AM
ValcoOscar   This is how I would like my car to look. White ...   Jan 30 2026, 07:50 AM
Pyetookh   I wonder why I like your color choice :idea: ...   Feb 5 2026, 01:19 AM
Jack Standz   [quote name='wonkipop' post='3237737' date='Dec 2...   Jan 27 2026, 11:05 AM
Jack Standz   Does your firewall shifter mount look something li...   Jan 27 2026, 11:19 AM
Pyetookh   Does your firewall shifter mount look something l...   Jan 29 2026, 11:34 PM
SirAndy   Does your firewall shifter mount look something li...   Jan 30 2026, 11:47 AM
914werke   Consider keeping it Willow Green. Cool color!   Jan 30 2026, 09:34 AM
Jack Standz   :agree: (we have a '72 originally in this colo...   Jan 30 2026, 11:25 AM
Pyetookh   :agree: (we have a '72 originally in this col...   Feb 5 2026, 02:28 AM
Pyetookh   My new tyres and wheels finally arrived so I pushe...   May 25 2026, 04:36 AM
4 User(s) are reading this topic (3 Guests and 0 Anonymous Users)
1 Members: bzettner
- Lo-Fi Version Time is now: 25th May 2026 - 08:30 AM
