> Oil line routing for a six.
pete-stevers
post Dec 16 2025, 09:32 PM
Shinee Side Up Prep and Paint
I am building my second 914 and putting a 2.4 six in and building it with hopes of building it out to a hotter 2.5 long stroke next winter... So I am putting in a external cooler up front. I am looking for the best ways to run the lines.. I dont want to run GT hardlines. What did you do?? Pictures welcome!!! (IMG:style_emoticons/default/biggrin.gif)
post Dec 17 2025, 08:22 PM
914-6 GT in waiting
On my 3.2 car, I ran a stainless line up the passenger side to the front cooler and then a second line from the cooler, down the driver side, to the oil tank. It’s a very clean setup since no line has to cross over or under the engine.
The GT style car that I’m currently building is using Ben’s GT hard lines. - Because they look great, work great and that’s what I wanted for this car.
There is no best way to do it. And really no cheap way either. The fittings, though not expensive, add up. I think Ben can make a kit that’s tried and true and has most everything needed to plumb the system. That can be a reasonable priced way to go since you aren’t buying things that don’t work together and then buying more stuff to make it work. BTDT.
Don’t be surprised if you are in for $3k +\- when you add it all up.
Montreal914
post Dec 19 2025, 04:49 PM
QUOTE(mepstein @ Dec 17 2025, 06:22 PM) *
I assume the thermostat is in the front at which point the lines need to come together? Are the connections to the cooler on the same side?
pete-stevers   Oil line routing for a six.   Dec 16 2025, 09:32 PM
Robarabian   Im gonna run hard lines.... but am interested in t...   Dec 16 2025, 09:56 PM
targa72e   I was just going to post the same question. I want...   Dec 16 2025, 10:56 PM
Steve   To each his own, but I installed AN12 steel braide...   Dec 17 2025, 12:20 AM
SirAndy   I am building my second 914 and putting a 2.4 si...   Dec 17 2025, 12:36 AM
Cairo94507   On my 2nd Six, 3.0, we ran braided SS lines up the...   Dec 17 2025, 07:27 AM
mb911   I ran solid lines under the chassis on one of my c...   Dec 17 2025, 11:13 AM
burton73   OK, my 6 number 41, when I got it, had this type...   Dec 17 2025, 03:04 PM
pete-stevers   Perhaps I should be more specific I am running a P...   Dec 17 2025, 03:11 PM
burton73   @pete-stevers pete-stevers The braded lines run ...   Dec 17 2025, 03:38 PM
burton73   I found some 2007 pictures Best Bob B   Dec 17 2025, 03:57 PM
pete-stevers   I found some 2007 pictures Best Bob B B...   Dec 19 2025, 01:47 PM
mepstein   On my 3.2 car, I ran a stainless line up the passe...   Dec 17 2025, 08:22 PM
Montreal914   On my 3.2 car, I ran a stainless line up the pass...   Dec 19 2025, 04:49 PM
sixnotfour   not cheap , just another way of routing.. https://...   Dec 17 2025, 09:49 PM
targa72e   Thanks for all the responses. And sorry to hijack ...   Dec 17 2025, 10:13 PM
SirAndy   What looks to make the most sense is to go in at t...   Dec 18 2025, 05:28 PM
Montreal914   What looks to make the most sense is to go in at ...   Dec 19 2025, 04:51 PM
SirAndy   [quote name='SirAndy' post='3237356' date='Dec 18 ...   Dec 19 2025, 06:36 PM
Montreal914   [quote name='SirAndy' post='3237356' date='Dec 18...   Dec 19 2025, 09:40 PM
SirAndy   There is always the debate or personal preferences...   Dec 19 2025, 09:52 PM
pete-stevers   There is always the debate or personal preference...   Dec 23 2025, 03:30 PM
pete-stevers   There is always the debate or personal preference...   Dec 23 2025, 03:37 PM
mepstein   I went up, over the wheel well and directly into t...   Dec 18 2025, 06:19 AM
pete-stevers   Thanks for the tip Andy!! In that caseI w...   Dec 19 2025, 01:43 PM
Tom1394racing   Hi Pete Here is what I did on my 914-6 GT project...   Dec 19 2025, 07:13 PM
Tom1394racing   I ran the stainless AN lines continuously along th...   Dec 19 2025, 07:22 PM
Tom1394racing   I used braided AN lines for the engine scavenge li...   Dec 19 2025, 07:27 PM
Tom1394racing   I brought the cooler lines and the oil tank feed l...   Dec 19 2025, 07:52 PM
pete-stevers   I brought the cooler lines and the oil tank feed ...   Dec 23 2025, 03:19 PM
Steve   I ran my AN12 steel braided lines the same as Tom....   Dec 23 2025, 03:42 PM
pete-stevers   Thanks Steve!   Jan 7 2026, 01:03 PM
brant   You want a minimum of -12 for a six Many people w...   Jan 8 2026, 09:12 AM
Steve   I’m running -12 for my cooler lines. Otto’s a...   Jan 8 2026, 10:44 AM
windforfun   So which steel surface is going to wear out first?...   Jan 8 2026, 10:45 AM
Steve   So which steel surface is going to wear out first...   Jan 9 2026, 11:41 AM
campbellcj   Mine are also AN-12 or maybe -16 run thru the rock...   Jan 9 2026, 12:14 PM
scrz914   I’m wondering if anyone has designed a grommet o...   Jan 9 2026, 12:45 PM
930cabman   I’m wondering if anyone has designed a grommet ...   Jan 9 2026, 01:11 PM
campbellcj   pretty sure mine has some rubber edge molding arou...   Jan 9 2026, 01:45 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 12:15 PM
