| Lulu13 |
Dec 21 2025, 11:09 AM
Newbie ![]() Group: Members Posts: 3 Joined: 1-May 23 From: Suisse Member No.: 27,327 Region Association: None |
Hello
I have a Porsche 914/4 2.0 1974 with D-Jetronic, I have an intake air leak on my throttle body shaft. Is it possible to overhaul this throttle body? in order to eliminate intake air leaks? thank you for your help Sincerely |
| fiacra |
Dec 21 2025, 12:33 PM
Person.Woman.Man.Camera.TV ![]() ![]() ![]() Group: Members Posts: 663 Joined: 1-March 19 From: East Bay Region - California Member No.: 22,920 Region Association: Northern California
Hello I have a Porsche 914/4 2.0 1974 with D-Jetronic, I have an intake air leak on my throttle body shaft. Is it possible to overhaul this throttle body? in order to eliminate intake air leaks? thank you for your help Sincerely Yes. As far as I know not really a job you can do on your own, unless you are a machinist and have all the appropriate tools. I would recommend you send it to Bill Fowler at Sparxwerks. International shipping might be slow and expensive, but you'll get quality work. You have to contact him first and not just send it in. I have two of his fuel pumps for my VWs and they are works of art. I have been planning on sending him my throttle body for restoration. Here's what he wrote to me about that service: "I do rebuild lots of the Porsche 914 throttle bodies. With that said, I do advise customers to close the throttle plates on the throttle body. Stick a bright light under the throttle body and snap a picture. This shows how much wear there is on the throttle plate by the light coming around the plate and in the throat of the throttle body. Not all of those throttle bodies can be rebuilt/restored. If it is a high mileage throttle body, the throttle shafts or bores wear and the plate can then shift and rub against the side of the throat. In really bad cases, the throttle plate is too worn and there's a deep groove in the throat where the plate rubbed. I have a customers 914 throttle body here now. It has light to moderate wear in those parts. I'll install new throttle shaft bushings to remove that wear and vacuum leaks and he'll have just a bit of wear on the throttle plate and throat but it will still be adjustable on the adjustment screw and work fine. If I ever find any free time, I'm going to try to get some new oversize throttle plates made. I can then bore out the throats of the throttle bodies and install the new throttle plates. The late Vanagon throttle bodies seem to all be really worn in that area. I charge $250 to rebuild those throttle bodies. You can see a few of the 914 throttle bodies restored along with other restored parts on my instagram page- https://www.instagram.com/sparxwerksllc/ |
Lulu13 914 2.0 throttle body Dec 21 2025, 11:09 AM
chmillman Yes, it's possible and indeed necessary. I do... Dec 21 2025, 11:50 AM
DC_neun_vierzehn Wow. His work is beautiful.
https://www.instagra... Dec 21 2025, 12:52 PM
chmillman A little closer to home - if you are indeed “en ... Dec 21 2025, 02:15 PM
JeffBowlsby
A little closer to home - if you are indeed “en... Dec 21 2025, 07:20 PM
Lulu13 Hello
Yes indeed, I live in Switzerland near Lau... Dec 21 2025, 02:56 PM
chmillman
Hello
Yes indeed, I live in Switzerland near La... Dec 21 2025, 03:01 PM
Lulu13 on se connais :D Dec 21 2025, 03:19 PM![]() ![]() |
Lo-Fi Version | Time is now: 21st December 2025 - 11:42 PM |
