| tomeric914 |
Aug 1 2010, 04:28 PM
One Lap of America in a 914! ![]() ![]() ![]() Group: Members Posts: 1,321 Joined: 25-May 08 From: Syracuse, NY Member No.: 9,101 Region Association: North East States
Back in February of '08, Cupomeat and Tomeric914 picked up this lovely 916 replica and a boatload of spare parts:
(IMG:http://www.914world.com/bbs2/uploads_offsite/farm5.static.flickr.com-9101-1280701715.1.jpg) Clean, one owner, Florida car, runs great, blah, blah, blah... When we picked it up, one carb was seized and the PO was "working on it". "Does the engine turn over?", I ask. "Last I knew it did", he says. Yea, maybe not: (IMG:http://www.914world.com/bbs2/uploads_offsite/farm5.static.flickr.com-9101-1280701715.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/farm5.static.flickr.com-9101-1280701716.3.jpg) Our first clue was when we pulled the oil drain plug and nothing came out. It was about 20 degrees in the garage so the water on the bottom of the engine was frozen. After using a torch to melt the water, the oil came out. http://www.youtube.com/watch?v=VuK9Z7fpgic The video above shows a nice ice cube stuck to the float of the one Weber that was still in the car. The PO said the car ran hot so they remove the rain tray to get more air in the engine compartment. The filters didn't have rain hats on and there were 1/4" to 1/2" gaps around the bottoms of the filters. The PO had made up some cheesedick plate for the bottom of the filter on but didn't understand the concept of flatness. (IMG:http://www.914world.com/bbs2/uploads_offsite/farm5.static.flickr.com-9101-1280701717.4.jpg) That was only the beginning of the fun. I've already forgotten about all the other half-assed fixes the PO did. My goal was to get the car on the road by April and on the track by the end of the summer. The PO had relocated the battery to the trunk which I wasn't crazy about. They also did some hellhole repair that looked to be ok. I finished their repair and but the battery tray back where it should be. At the same time, I rebuilt the 2.0 engine using A LOT of the spare parts we had (heads were one of those spare parts). What amazed me was the amount of parts that were in their original shipping boxes dated from the mid 1980's with 2nd day air! They sat for 20+ years! Here is the engine in the car around the middle of April all set to go. (IMG:http://www.914world.com/bbs2/uploads_offsite/farm5.static.flickr.com-9101-1280701717.5.jpg) So now it has 96mm KB pistons and AA cylinders (which, BTW suck. AA used to have decent cylinders). It is now a 2056 with 40IDFs and what appears to be an old S&S exhaust setup. I put the lowest profile tires I could find on the crappy set of cookie cutters we had. (IMG:http://www.914world.com/bbs2/uploads_offsite/farm5.static.flickr.com-9101-1280708541.1.jpg) For the next few months I drive it and sort out the various issues, rebuild all the brake calipers, remove the brake line tee that the DAPO put in and get a nice reconditioned brake pressure regulator from PMB. Sign up for my first track event at Watkins Glen and before going there, install an oil cooler. (IMG:http://www.914world.com/bbs2/uploads_offsite/farm5.static.flickr.com-9101-1280708542.2.jpg) Then I found some rust in the long that needed attention. Luckily, not too bad... yet. Cut it out and repair it. (IMG:http://www.914world.com/bbs2/uploads_offsite/farm5.static.flickr.com-9101-1280708542.3.jpg) Then off to the Glen! |
| 930cabman |
Dec 21 2025, 01:52 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,572 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
just happened on this build, thanks for documenting.
Is your only teener a track car? |
| tomeric914 |
Dec 21 2025, 06:55 PM
tomeric914 Tomeric Build Thread Aug 1 2010, 04:28 PM
tomeric914 At the Glen, the car feels a little loose in the r... Aug 1 2010, 07:00 PM
Ericv1 Nice, I'm liking the 916 front and rear. If p... Aug 1 2010, 07:31 PM
tomeric914 Oops, I can't forget the garage floor rebuild ... Aug 1 2010, 08:01 PM
Cupomeat Having seen pix throughout this process, it is ama... Aug 2 2010, 09:13 AM
Nürburg Nomad Have any updates and particularly current side pro... May 13 2011, 01:39 AM
Cairo94507 Wow! Very nice work and I too like the stock ... May 13 2011, 06:58 AM
rick 918-S Drive it like ya stole it! :headbanger: May 13 2011, 07:06 AM
PanelBilly I need to component you on the nice balance of res... May 13 2011, 08:36 AM
tomeric914 Thanks PB. That means a lot to me considering the... May 13 2011, 09:32 AM
PeeGreen 914 I like the progression :beer2: . Looking good :hea... May 13 2011, 09:40 AM
Cupomeat No doubt that you have made HUGE changes on this c... May 13 2011, 09:41 AM
abnrdo :beer2: Nice work!! Inspiration for me wh... May 14 2011, 04:00 AM
tomeric914 Getting back to it, I'll start back at May 201... May 15 2011, 10:02 AM
FourBlades Great work man, keep the pictures coming.
I also ... May 15 2011, 10:39 AM
tomeric914
I also like how you have kept it on the road most... May 15 2011, 10:51 AM
markb :wub: May 15 2011, 10:58 AM
tomeric914 From the start of this build, the priorities were:... May 15 2011, 06:11 PM
Cupomeat As always Tom, First Class work!
Looks great... May 15 2011, 09:33 PM
jaxdream I could be wrong , but looks like you are missing ... May 16 2011, 08:52 AM
ewdysar Nice work, Tom!
I'm getting ready to ge... May 16 2011, 11:50 AM
tomeric914
I could be wrong , but looks like you are missing... May 16 2011, 12:08 PM
jaxdream
I could be wrong , but looks like you are missin... Jun 2 2011, 04:32 PM
tomeric914 Update: Finished up the exhaust. This is a Magan... May 22 2011, 06:49 PM
tomeric914 Update: Finally done with the breather. There... May 28 2011, 11:06 AM
Cupomeat Looks GREAT!
I guess it is more of a NARP wit... Jun 1 2011, 03:05 PM
tomeric914 Yea, but the breather says Moroso so it must be fa... Jun 1 2011, 06:20 PM
kconway Are those breather/catch cans required for street ... Jun 1 2011, 08:01 PM
tomeric914
Are those breather/catch cans required for street... Jun 2 2011, 10:17 AM
nsr-jamie You do great work!! Car looks excellent no... Jun 1 2011, 09:37 PM
Cupomeat
You do great work!! Car looks excellent n... Jun 1 2011, 09:50 PM
tomeric914 My solution to turn the oil cooler fan on:
Honda ... Jun 15 2011, 09:27 PM
Cupomeat
Honda... Jun 15 2011, 09:39 PM
pete-stevers I spotted a single cab in one of those pics..... Jun 15 2011, 11:49 PM
tomeric914
... Jun 16 2011, 06:31 AM
tomeric914 So I tackled the oil leaks from my chain boxes wit... Jun 26 2011, 09:16 PM
Eric_Shea Looking great Tom!
I like the fact that you ... Jun 28 2011, 09:29 PM
Cupomeat
Looking great Tom!
I like the fact that you ... Jul 1 2011, 08:54 AM
tomeric914
Eric, according to your logical pattern recogniti... Jul 1 2011, 03:52 PM
Cupomeat Good point, fixing brakes BEFORE something breaks ... Jul 2 2011, 09:14 PM
Cupomeat
Good point, fixing brakes BEFORE something breaks... Jul 3 2011, 08:36 PM
Cupomeat Having had a ride now, all I can say is that I wan... Jul 3 2011, 08:56 PM
tomeric914
Great car, and sorry about your air dam(n) Tom.
... Jul 4 2011, 06:27 PM
tomeric914 ok, so I've been busy with a few things and ha... Aug 14 2011, 09:45 AM
AZ914 The cooler looks great! I'm about to add ... Aug 14 2011, 04:14 PM
Scarlet75 I really need to get down there and check this 914... Aug 14 2011, 04:19 PM
tomeric914
The cooler looks great! I'm about to add... Aug 14 2011, 09:23 PM
tomeric914 I've been busy this winter working on a couple... Mar 25 2012, 09:54 AM
Cupomeat Damn, looking forward to seeing this car in July. ... Apr 20 2012, 01:41 PM
tomeric914
Damn, looking forward to seeing this car in July.... Apr 20 2012, 03:53 PM
rick 918-S Very nice! Apr 21 2012, 06:11 AM
jmill Still one of my favorite cars. :trophy: Apr 21 2012, 10:47 AM
tomeric914
Thanks... Apr 21 2012, 02:29 PM
tomeric914 I need to get more pictures up, but in the meantim... May 19 2012, 07:42 PM
Cupomeat Fantastic!!!
You almost have your dai... May 19 2012, 10:09 PM
tomeric914 More progress:
Added another layer of Damplifier ... Jul 5 2012, 06:36 AM
JmuRiz Looking good, good to know the rear cooler was onl... Aug 2 2012, 01:37 PM
FourBlades More nice work!
How do you like the kirkey se... Aug 3 2012, 08:52 AM
tomeric914
Looking good, good to know the rear cooler was on... Aug 3 2012, 08:04 PM
Cupomeat A good shot of Tom at WG.
That car is amazingly f... Sep 6 2012, 04:44 PM
tomeric914 Going faster means I need to scrub off more speed ... Sep 6 2012, 07:15 PM
somd914 Tom,
Awesome build.
I'm loving your old 2056... Sep 8 2012, 06:34 AM
tomeric914 Been busy this winter but haven't posted much ... Apr 5 2014, 08:42 PM
jaxdream Forgive my ignorance Tom , what was the "bloc... Apr 6 2014, 09:14 AM
tomeric914
Forgive my ignorance Tom , what was the "blo... Apr 6 2014, 09:41 AM
tomeric914 Finally added my Sheridan rear spoiler. One of th... Apr 7 2014, 09:12 PM
arkitect Cool thread, have not seen this type of rear spoil... May 2 2015, 10:18 AM
tomeric914
Cool thread, have not seen this type of rear spoi... May 2 2015, 12:58 PM
Maltese Falcon Excellent craftsmanship here Tom...I dig the silve... May 2 2015, 03:58 PM
Luke M Hey Tom,
Nice car you got there. Would you be wil... May 3 2015, 06:48 PM
tomeric914 Just updating my thread with post I recently made... Jun 30 2017, 06:49 PM
tomeric914 With the Christmas break, I finally took the time ... Jan 14 2018, 11:02 AM
Cupomeat Looks great! Let's see if the rotor cracki... Jan 15 2018, 01:00 PM
totle Tomeric, can you please share a picture of how you... Sep 7 2018, 02:18 AM
tomeric914
...can you please share a picture of how you rout... Sep 7 2018, 04:07 PM
totle Thanks. Ok, thought you routed it outside the heat... Sep 8 2018, 02:49 PM
tomeric914 Late update...
A few years ago, when @cupomeat ... Jan 19 2020, 12:24 PM
tomeric914 Well apparently I have not updated this thread in ... Feb 10 2023, 09:50 PM
tomeric914 More updates incoming. After 12 years of abuse an... Feb 18 2023, 06:35 PM
barefoot
It does both. ... Dec 25 2025, 08:59 AM
tomeric914
Yes, committing to a cage & race seat with 5 ... Dec 25 2025, 09:42 AM
mgp4591 How are you liking the Corrado brake m/c? I'v... Dec 21 2025, 11:37 PM
tomeric914
How are you liking the Corrado brake m/c? I... Dec 22 2025, 07:51 AM
930cabman From what i could see there was some "heavy... Dec 22 2025, 09:46 AM
Cupomeat Yeah, I even did a bunch of videos for that OLOA, ... Dec 28 2025, 02:15 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 06:45 PM |
