| pete-stevers |
Dec 16 2025, 09:32 PM
Shinee Side Up Prep and Paint ![]() ![]() ![]() ![]() Group: Members Posts: 2,672 Joined: 10-October 04 From: Abbotsford,BC, Canada Member No.: 2,914 Region Association: Pacific Northwest
I am building my second 914 and putting a 2.4 six in and building it with hopes of building it out to a hotter 2.5 long stroke next winter... So I am putting in a external cooler up front. I am looking for the best ways to run the lines.. I dont want to run GT hardlines. What did you do?? Pictures welcome!!! (IMG:style_emoticons/default/biggrin.gif)
| targa72e |
Dec 17 2025, 10:13 PM
Member ![]() ![]() Group: Members Posts: 297 Joined: 11-September 16 From: colorado Member No.: 20,392 Region Association: None
Thanks for all the responses. And sorry to hijack the original posters thread. I purchased Ben's hard lines but decided I did not want to run the lines thru the passenger compartment. My oil cooler I am using has the inlet and outlet on the passenger side. I am looking to run lines up and back on the passenger side. I would also consider one up the passenger and one back down the drivers side. I do not plan on going into the Frunk at the very front of the car. Most of the installs I have seen that run lines down the passenger side come out into the frunk at the passenger side rear. This requires going into the space occupied by the gas tank and then coming into the frunk. What I have not found pictures of is where people go into the gas tank area on the passenger fender. Would love some pics. What looks to make the most sense is to go in at the top rear of the passenger fender and then down under the tank to come into the frunk. Any pics of this type of configuration and comments welcomed.
john |
| SirAndy |
Dec 18 2025, 05:28 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,469 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
What looks to make the most sense is to go in at the top rear of the passenger fender and then down under the tank to come into the frunk. Just be aware that any significant change in elevation will make oil changes a bitch. Going over the top of the fender will make the lines run higher than the top of the oil tank which may also introduce issues. (IMG:style_emoticons/default/popcorn[1].gif) |
| Montreal914 |
Dec 19 2025, 04:51 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,072 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California
What looks to make the most sense is to go in at the top rear of the passenger fender and then down under the tank to come into the frunk. Just be aware that any significant change in elevation will make oil changes a bitch. Going over the top of the fender will make the lines run higher than the top of the oil tank which may also introduce issues. (IMG:style_emoticons/default/popcorn[1].gif) Isn't this the situation on any 911 with front cooler? |
| SirAndy |
Dec 19 2025, 06:36 PM
What looks to make the most sense is to go in at the top rear of the passenger fender and then down under the tank to come into the frunk. Just be aware that any significant change in elevation will make oil changes a bitch. Going over the top of the fender will make the lines run higher than the top of the oil tank which may also introduce issues. (IMG:style_emoticons/default/popcorn[1].gif) Isn't this the situation on any 911 with front cooler? And your point is? (IMG:style_emoticons/default/confused24.gif) If you have a significant high point in your routing, you will need 2 (or more) drain points in the system. On my car the highest point is the small hump for the steering rack which can be overcome by jacking up the front of the car. I only have one drain at the lowest point close to the tank. If you route your lines over the top of the fender you will need to add another drain point to the front of the car to be able to get oil out of that part of the system. (IMG:style_emoticons/default/popcorn[1].gif) |
| Montreal914 |
Dec 19 2025, 09:40 PM
What looks to make the most sense is to go in at the top rear of the passenger fender and then down under the tank to come into the frunk. Just be aware that any significant change in elevation will make oil changes a bitch. Going over the top of the fender will make the lines run higher than the top of the oil tank which may also introduce issues. (IMG:style_emoticons/default/popcorn[1].gif) Isn't this the situation on any 911 with front cooler? And your point is? (IMG:style_emoticons/default/confused24.gif) If you have a significant high point in your routing, you will need 2 (or more) drain points in the system. On my car the highest point is the small hump for the steering rack which can be overcome by jacking up the front of the car. I only have one drain at the lowest point close to the tank. If you route your lines over the top of the fender you will need to add another drain point to the front of the car to be able to get oil out of that part of the system. (IMG:style_emoticons/default/popcorn[1].gif) Simply wondering what issues it was introducing, other than the drainage problem. I did always wonder how 911s were draining the cooler lines. (IMG:style_emoticons/default/confused24.gif) There is always the debate or personal preferences of having (or not) hot oil lines inside the cabin due to heat but mostly risk in case of failure or collision. Failure probably is low, but collision is not controlable. As Mark mentioned, there doesn't seem to be a perfect option only compromise. |
| SirAndy |
Dec 19 2025, 09:52 PM
There is always the debate or personal preferences of having (or not) hot oil lines inside the cabin due to heat but mostly risk in case of failure or collision. Failure probably is low, but collision is not controlable. I've seen oil lines come apart at the track twice (not on my car), one time resulting in a spectacular fire. Both times the failures were at the fittings, not the lines themselves. So yes, failure and collision are most certainly a concern. (IMG:style_emoticons/default/unsure.gif) |
| pete-stevers |
Dec 23 2025, 03:30 PM
There is always the debate or personal preferences of having (or not) hot oil lines inside the cabin due to heat but mostly risk in case of failure or collision. Failure probably is low, but collision is not controlable. I've seen oil lines come apart at the track twice (not on my car), one time resulting in a spectacular fire. Both times the failures were at the fittings, not the lines themselves. So yes, failure and collision are most certainly a concern. (IMG:style_emoticons/default/unsure.gif) That is another big concern of mine... hoses coming apart.. What fittings are the most pressure resitant? Andy Do you recall the fittings that where used on the two cars.. Engines are worth to much today to sacrifice to poor fittings (IMG:style_emoticons/default/dry.gif) What type of pressures run through the lines? I will be using a stock pump not a four rib. I figure pressures can run pretty high on a cold start up... |
pete-stevers Oil line routing for a six. Dec 16 2025, 09:32 PM
Robarabian Im gonna run hard lines.... but am interested in t... Dec 16 2025, 09:56 PM
targa72e I was just going to post the same question. I want... Dec 16 2025, 10:56 PM
Steve To each his own, but I installed AN12 steel braide... Dec 17 2025, 12:20 AM
I am building my second 914 and putting a 2.4 si... Dec 17 2025, 12:36 AM
Cairo94507 On my 2nd Six, 3.0, we ran braided SS lines up the... Dec 17 2025, 07:27 AM
mb911 I ran solid lines under the chassis on one of my c... Dec 17 2025, 11:13 AM
burton73 OK, my 6 number 41, when I got it, had this type... Dec 17 2025, 03:04 PM
pete-stevers Perhaps I should be more specific
I am running a P... Dec 17 2025, 03:11 PM
burton73 @pete-stevers pete-stevers
The braded lines run ... Dec 17 2025, 03:38 PM
burton73 I found some 2007 pictures
Best Bob B Dec 17 2025, 03:57 PM
pete-stevers
Best Bob B
B... Dec 19 2025, 01:47 PM
mepstein On my 3.2 car, I ran a stainless line up the passe... Dec 17 2025, 08:22 PM
Montreal914
On my 3.2 car, I ran a stainless line up the pass... Dec 19 2025, 04:49 PM
sixnotfour not cheap , just another way of routing..
https://... Dec 17 2025, 09:49 PM
pete-stevers
There is always the debate or personal preference... Dec 23 2025, 03:37 PM
mepstein I went up, over the wheel well and directly into t... Dec 18 2025, 06:19 AM
pete-stevers Thanks for the tip Andy!! In that caseI w... Dec 19 2025, 01:43 PM
Tom1394racing Hi Pete
Here is what I did on my 914-6 GT project... Dec 19 2025, 07:13 PM
Tom1394racing I ran the stainless AN lines continuously along th... Dec 19 2025, 07:22 PM
Tom1394racing I used braided AN lines for the engine scavenge li... Dec 19 2025, 07:27 PM
Tom1394racing I brought the cooler lines and the oil tank feed l... Dec 19 2025, 07:52 PM
pete-stevers
I brought the cooler lines and the oil tank feed ... Dec 23 2025, 03:19 PM
Steve I ran my AN12 steel braided lines the same as Tom.... Dec 23 2025, 03:42 PM
pete-stevers Thanks Steve! Jan 7 2026, 01:03 PM
brant You want a minimum of -12 for a six
Many people w... Jan 8 2026, 09:12 AM
Steve I’m running -12 for my cooler lines. Otto’s a... Jan 8 2026, 10:44 AM
windforfun So which steel surface is going to wear out first?... Jan 8 2026, 10:45 AM
Steve
So which steel surface is going to wear out first... Jan 9 2026, 11:41 AM
campbellcj Mine are also AN-12 or maybe -16 run thru the rock... Jan 9 2026, 12:14 PM
scrz914 I’m wondering if anyone has designed a grommet o... Jan 9 2026, 12:45 PM
930cabman
I’m wondering if anyone has designed a grommet ... Jan 9 2026, 01:11 PM
campbellcj pretty sure mine has some rubber edge molding arou... Jan 9 2026, 01:45 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 10:41 AM |
