| UROpartsman |
Nov 14 2025, 01:26 PM
Member ![]() ![]() Group: Members Posts: 301 Joined: 22-October 15 From: Simi Valley, CA Member No.: 19,288 Region Association: None
URO Parts' Rear Stabilizer Bar Install Kit 91450125910K makes it easier to install a rear sway bar in your 914, just add a bar and end links! (Welding and painting is required.) This kit is now available from Porsche specialists such as:
Auto Atlanta in Marietta, GA: 914 501 259 10K: STABILIZER BAR INSTALL KIT R91450125910K Rear Kit Contains:
Tags: 91450125910, 914 501 259 10 Attached image(s)
| bdstone914 |
Dec 12 2025, 10:27 PM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,421 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
URO Parts' Rear Stabilizer Bar Install Kit 91450125910K makes it easier to install a rear sway bar in your 914, just add a bar and end links! (Welding and painting is required.) This kit is now available from Porsche specialists such as: Auto Atlanta in Marietta, GA: 914 501 259 10K: STABILIZER BAR INSTALL KIT R91450125910K Rear Kit Contains:
You also need the correct shock bolts. Tags: 91450125910, 914 501 259 10 |
| UROpartsman |
Dec 26 2025, 02:00 PM
You also need the correct shock bolts. (IMG:http://www.914world.com/bbs2/uploads/post-23905-1623631668_thumb.jpg) Thanks for the tip! Unfortunately the minimum quantity needed to do a production run of Bearing Pin 914 333 565 01 would be more than 80 years of inventory, so we won't be able to make it work. |
| bdstone914 |
Dec 28 2025, 02:10 AM
@Uropartsman
Thanks for the tip! Unfortunately the minimum quantity needed to do a production run of Bearing Pin 914 333 565 01 would be more than 80 years of inventory, so we won't be able to make it work. [/quote] Aftermarket sway bar shock bolts are available from Prekom USA. Are the weld on brackets for early or late cars? |
UROpartsman URO Parts Rear Stabilizer Bar Install Kit 91450125910K Nov 14 2025, 01:26 PM
UROpartsman You also need the correct shock bolts.
Auto Atlant... Jan 7 2026, 01:41 PM![]() ![]() |
Lo-Fi Version | Time is now: 31st October 2026 - 10:32 AM |
