| DennisV |
Dec 6 2025, 11:09 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,031 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California
I'm fumbling my way through the engine harness wiring for our 914-6 engine with CDI and Marelli distributor (no condenser). It's on a test stand at the moment, but I don't think that will complicate these questions. I have a new aftermarket engine harness.
Can anyone confirm or clarify the following: 1. Would the coil ground ring terminal (brown) go to the fan housing stud where the coil bracket mounts? 2. There is a ring terminal branching off the Points wire (black-blue) labeled CDI ground. AFAIK the ground terminals on the CDI are male spades. (IMG:style_emoticons/default/blink.gif) Not sure what to do with this. I guess I could try to fit it on the terminal retaining bolt? Or am I misunderstanding the intended location for this? 3. On the diagram I have there is a IGN_Coil_GND to CDI_GND connection (combined with Throttle_Position_GND). Do I still need to make a brown wire going from the Coil negative post to fan housing stud coil mounting bracket? 4. With CDI, there is no wire directly from the coil to the distributor? Thanks. ![]() |
| DennisV |
Dec 27 2025, 05:14 PM
A follow up on this. I see a female spade connector that attaches to the distributor points terminal. It appears to carry two wires:
1. Black to CDI.1 2. Black-blue to 14_Pin.2 Where does that Black-blue terminate on the other side of the 14_Pin? I have looked at the main chassis harness, but couldn't figure it out. This is a case where the test stand is complicating things, as I obviously won't be connecting the engine harness 14-pin connector to the relay board. So I'm assuming I need to jump that black-blue wire to something? |
| IronHillRestorations |
Dec 28 2025, 12:14 PM
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,956 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None
A follow up on this. I see a female spade connector that attaches to the distributor points terminal. It appears to carry two wires: 1. Black to CDI.1 2. Black-blue to 14_Pin.2 Where does that Black-blue terminate on the other side of the 14_Pin? I have looked at the main chassis harness, but couldn't figure it out. This is a case where the test stand is complicating things, as I obviously won't be connecting the engine harness 14-pin connector to the relay board. So I'm assuming I need to jump that black-blue wire to something? It goes through the relay board, to the BHZ can, to the tach. As I understand it the BHZ can changes the signal from the points so it works the stock 914-6 tach properly. Later 911’s don’t need the can. |
DennisV 914-6 Engine Harness Wiring Dec 6 2025, 11:09 AM
rgalla9146 1 Yes
2 Black/blue w ring goes to coil
3 Yes... Dec 6 2025, 02:53 PM
DennisV
1 Yes
3 Ye... Dec 6 2025, 05:28 PM
rgalla9146 Coil Dec 6 2025, 02:54 PM
rgalla9146 Hey Michael
The ring terminal near the dizzy ... Dec 6 2025, 08:42 PM
DennisV
The ring terminal near the dizzy spade attaches t... Dec 7 2025, 07:43 AM
DennisV
It goes through the relay board, to the BHZ can, ... Dec 28 2025, 12:46 PM![]() ![]() |
Lo-Fi Version | Time is now: 29th September 2026 - 01:12 PM |
