> 100 micron pre pump fuel filter, 75 front pump location
rfinegan
post Nov 4 2025, 01:21 PM
I am looking to route my fuel lines one more time (no kinks). While in there I will change my line to AN fittings and braided fuel lines. Does any one have a recommendation for a Pre fuel filter of 100 microns? I have a good post hi pressure filter in place already
Something like this?
https://www.summitracing.com/parts/sum-2301...OlOTtQ0t6Qf48Fc
jim_hoyland
post Dec 31 2025, 09:12 AM
Get that VIN ?
As to “ NO pre pump filter aside from the tank screen” I have wondered why this is a good idea. Suppose that screen get clogged up: And your out on an open road ?
JamesM
post Jan 1 2026, 10:17 PM
QUOTE(jim_hoyland @ Dec 31 2025, 08:12 AM) *
No screen at all is also an acceptable (and possibly preferable) option. This is how it was done on Vanagons.
You want the least amount of restriction pre pump. Shortest, fatest, straightest suction lines possible with no filters restricting flow. Vacuum on the inlet side of the pump can cavitate the fuel which leads to a noisier fuel pump as well as potentially causing damage/shorter life to the pump. Depending on the condition and routing of the fuel lines it can also cause the feed line to collapse on itself causing fuel starvation.
Injectors require filtered fuel for long life the pump doesn't, it needs unrestricted fuel flow.
Superhawk996
post Jan 2 2026, 06:57 AM
QUOTE(JamesM @ Jan 2 2026, 12:17 AM) *
Injectors require filtered fuel for long life the pump doesn't . . .
Maybe . . .
If you’re going to delete all pre-filtration you better know what type of fuel pump you’re using (turbine, gearotor, or rollervane, diaphragm or vibrating plunger like a Facet).
Turbine pumps are not forgiving if run without pre-filtration.
A 100 micron pre-filter doesn’t cause any significant restriction to the pump inlet nor does the OEM sock.
rfinegan   100 micron pre pump fuel filter   Nov 4 2025, 01:21 PM
rfinegan   Evil works fuel filter and 6-an lines still more...   Dec 1 2025, 01:13 PM
JamesM   I am assuming this is a fuel injected car? if not...   Dec 1 2025, 10:48 PM
rfinegan   I am assuming this is a fuel injected car? if no...   Dec 2 2025, 12:11 AM
JamesM   If you are updating things: NO pre pump filter as...   Dec 1 2025, 10:47 PM
VaccaRabite   @rfinegan For the front trunk fuel line kinks, I...   Dec 2 2025, 08:28 AM
Mitox   I purchased one with an integrated cut-off valve t...   Dec 2 2025, 09:30 AM
campbellcj   I have a Canton filter up front post-pump; all AN-...   Dec 2 2025, 10:30 AM
rfinegan   spin on fuel filter installation   Dec 30 2025, 01:19 PM
rfinegan   I added spin on fuel filter under the trunk spring...   Dec 30 2025, 01:21 PM
rfinegan   filter with swivel 90 degree barbs   Dec 30 2025, 01:25 PM
rfinegan   another   Dec 30 2025, 01:27 PM
rfinegan   hoses snd clamps   Dec 30 2025, 01:29 PM
rfinegan   For summary, The 75 now has a 100 micron pre filte...   Dec 31 2025, 08:39 AM
jim_hoyland   As to “ NO pre pump filter aside from the tank s...   Dec 31 2025, 09:12 AM
Superhawk996   As to “ NO pre pump filter aside from the tank ...   Dec 31 2025, 12:24 PM
JamesM   As to “ NO pre pump filter aside from the tank ...   Jan 1 2026, 10:17 PM
Superhawk996   As to “ NO pre pump filter aside from the tank...   Jan 2 2026, 06:57 AM
JamesM   [quote name='JamesM' post='3239141' date='Jan 2 2...   Jan 23 2026, 05:39 PM
Geezer914   Mount your pump and filter under the steering rack...   Dec 31 2025, 09:27 AM
jim_hoyland   What is the micron filtering for these ?   Jan 2 2026, 05:45 PM
Superhawk996   What is the micron filtering for these ? Pretty ...   Jan 2 2026, 08:25 PM
jim_hoyland   What is the micron filtering for these ? Pretty...   Jan 2 2026, 09:32 PM
rfinegan   AI gave me a 40-60 range for cellulose/paper filte...   Jan 3 2026, 03:43 AM
rfinegan   Wrapping up the new fuel tank and AN lines today. ...   Jan 11 2026, 08:26 AM
rfinegan   WOW, I was thinking I was done. Now I see the J b...   Jan 18 2026, 10:26 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 07:24 AM
