| TRP |
Jan 2 2026, 03:24 PM
Member ![]() ![]() Group: Members Posts: 158 Joined: 2-September 23 From: Morgan Hill, CA Member No.: 27,559 Region Association: None
As the title states, I'm having Ken Jansen build me a 2056 for my current 1.8l powered 914. I plan on keeping the LJet and 1.8 heat exchanger / Bursch exhaust system.
We are starting with a 1.8 block and 1.8 heads (I purchased a 1.8 core) locally. Ken will be providing a 2.0 std/std crank and all of the required bearings and gaskets/seals. I have already purchased: - Raby 9590 Deluxe Cam (with Cam Gear, new lifters, pushrod, heavy duty rocker shafts, springs, and 911 valve adjustment feet.) - 1.7 OEM Rocker Arms - OEM oil cooler - 30mm Full flow oil pump & Full flow (purchased from Raby) - ARP Case Studs - ARP Head Studs - JE Forged 96mm Pistons and cylinders - Matched set OEM std 2.0 Rods - Oil galley threaded plugs - GoWesty Throttle body - Setrab Series 6, 25 row oil cooler with fan pack and thermostat - New OEM clutch pressure plate and friction disc Ken will be balancing the complete rotating assembly, including flywheel and pressure plate. He will also rebuilt the 1.8 heads, most likely going with 2.0 sized valves, May go slightly larger to match Jake's suggested valve sizes (Ken isn't sure about the necessity, I personally think we should.) We are cleaning the oil gallies and tapping the plug holes. Shooting for 8.5:1 compression ratio. Anything else I should consider? Thanks, Ted |
| emerygt350 |
Jan 2 2026, 04:41 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,431 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
Maybe i missed it but that raby cam might be good. I have heard it helps keep the temps down. Others know better than I though.
TRP Having a 2056 built for my 75 914 Jan 2 2026, 03:24 PM
914werke You might consider 2.0L heads rather than putting ... Jan 2 2026, 05:40 PM
TRP I spoke with Jake about my desire to keep the L Je... Jan 2 2026, 08:21 PM
emerygt350 Ahh, I see the cam now. Jan 2 2026, 08:54 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd January 2026 - 10:50 PM |
