> Unknown fastener, What is that?
trojanhorsepower
post Jan 4 2026, 08:51 AM
My guess is the secondary oil pressure control. Is that correct? What fastener type/size is that?Attached Image
Its on this case
trojanhorsepower
post Jan 5 2026, 05:39 PM
OK, so the reason to block it off is to get higher oil pressure when the motor is hot, I believe this is a common upgrade by performance engine builders.
I am going to leave it stock for now.
It is a 1.7, your are correct there, but I think all original type 4 914 engines have this part. My reading indicates that the second oil pressure control valve was standard on type 4 engines until VW started to experiment with hydraulic lifters. At that point they stopped milling out the passage or taping the threads. Either way it is definitely present on my 1974 2.0l GA case.
- Lo-Fi Version Time is now: 8th January 2026 - 10:30 AM
