> Engine Tin Restoration
Aayala
post Jan 5 2026, 09:28 PM
Hello all, kept trying to look in the forum for hopefully an old article of someone going through this but no luck. I am in the process of having my cylinder heads vapor blasted and about to send the case over for machining and removing of the welded oil galley plugs.
I am left with all of the other rusty engine tins, cylinder head covers, fan housing, brackets, etc...
What is the best way to tackle all of these to restore them properly? Is a chemical bath a good way to go about it and efficient? I have someone that can do this locally but not sure if there is any concern about this? I was thinking of painting them after the bath with some rust prevention like a paint primer and then hitting with some coats of flat black paint or just rustoleoum paint.
Any recommendations on what is the most efficient? or is elbow grease and some brushes the way to go?
and any paint in specific you all have used? maybe for cooling purposes not that the engine tin should get that hot?
thanks in advance!
Dlee6205
post Jan 6 2026, 06:02 AM
QUOTE(mepstein @ Jan 5 2026, 10:31 PM) *
Find a place to glass bead blast and powder coat.
I'll second this. This is the easy button, and also not too expensive usually.
Aayala   Engine Tin Restoration   Jan 5 2026, 09:28 PM
mepstein   Find a place to glass bead blast and powder coat. ...   Jan 5 2026, 09:31 PM
Dlee6205   Find a place to glass bead blast and powder coat....   Jan 6 2026, 06:02 AM
Root_Werks   Find a place to glass bead blast and powder coat...   Jan 7 2026, 10:01 AM
mepstein   Either your machinist or your vapor hone person wi...   Jan 6 2026, 07:17 AM
barefoot   I went with a local sand blast outfit, then they e...   Jan 6 2026, 09:14 AM
930cabman   Many of us here are in the CSOB camp some degreas...   Jan 6 2026, 09:51 AM
Nogoodwithusernames   Many of us here are in the CSOB camp some degrea...   Jan 6 2026, 11:56 AM
TRP   [quote name='930cabman' post='3239702' date='Jan ...   Jan 6 2026, 04:14 PM
chmillman   If you’re going to go with spray cans, I might l...   Jan 6 2026, 04:25 PM
Chad911sc   I restored all the tin and painted them myself. To...   Jan 6 2026, 05:23 PM
mepstein   You lost me at 3-4 days.   Jan 6 2026, 06:14 PM
930cabman   @Chad does your wife know you baked engine tins ...   Jan 6 2026, 06:18 PM
TRP   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Jan 6 2026, 06:21 PM
Chad911sc   lol…I have been happily single for 12 years. How...   Jan 7 2026, 06:40 AM
Aayala   Awesome! Thank you for the recommendations y...   Jan 7 2026, 08:55 AM
mepstein   At my shop, that’s a couple hours of work and ma...   Jan 7 2026, 11:53 AM
TRP   I called around down here where I am located, to ...   Jan 7 2026, 02:17 PM
wonkipop   I called around down here where I am located, to...   Jan 7 2026, 03:03 PM
mepstein   I called around down here where I am located, to...   Jan 7 2026, 03:16 PM
TRP   I called around down here where I am located, t...   Jan 7 2026, 03:52 PM
- Lo-Fi Version Time is now: 9th January 2026 - 09:45 AM
