| SKL1 |
Jan 5 2026, 09:52 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,744 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest
Trying to figure out how accurate the OEM voltmeter is in my '73 2.0. To make a long story shorter the engine in the car is a much modified 1.9 from my '71, with approx 120K miles on the alternator.
Voltmeter reads around 11V and drops to 10 if I turn on the headlights. Immediately goes back to 11 or just over that with the lights turned off. Replaced the voltage regulator this AM and did a test drive with no change. Gauge never gets close or above 12V. Makes me afraid to drive it at night with the lights on and go very far. Do I need to go through the hassle of rebuilding the alternator or trying the alternator from the original 2.0 engine that has about 70K miles on it? Better way to get a more accurate reading of actual voltage?? I hate electrical issues!!!! TIA. |
| emerygt350 |
Jan 6 2026, 06:36 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,436 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
It's really not the voltmeter, I checked mine against a nice multimeter and it shows pretty dead on to that. The problem is where it is tapped into the system. Unless you run a direct wire from the volt meter to the battery you really only have another method of knowing your brake light is working.
I put a relay inline using the original wiring of the volt meter to trigger it. I have fused wire running from the relay to the battery and to the relay -> volt meter. The volt meter is now key activated (using the original wiring) and it only tells me what the battery is seeing. I went from a situation you describe to a nice steady 13.8. I also use a digital adjustable voltage regulator and highly recommend them. Cheap, sturdy, and fits the slot. |
SKL1 Voltmeter reading? Accuracy? Jan 5 2026, 09:52 PM
mjrrti
Trying to figure out how accurate the OEM voltmet... Jan 5 2026, 11:16 PM
mjrrti The brand didn’t show in my pic but it is zeehoo... Jan 5 2026, 11:22 PM
930cabman I have found voltmeter readings somewhat erratic, ... Jan 6 2026, 05:58 AM
GregAmy
Trying to figure out how accurate the OEM voltmet... Jan 6 2026, 08:15 AM
SKL1 Thanks. The meter in the lighter sounds great but... Jan 6 2026, 11:47 AM![]() ![]() |
Lo-Fi Version | Time is now: 9th January 2026 - 09:44 AM |
