| Aayala |
Jan 5 2026, 09:28 PM
Member ![]() ![]() Group: Members Posts: 50 Joined: 7-July 25 From: Austin Tx Member No.: 28,874 Region Association: South East States |
Hello all, kept trying to look in the forum for hopefully an old article of someone going through this but no luck. I am in the process of having my cylinder heads vapor blasted and about to send the case over for machining and removing of the welded oil galley plugs.
I am left with all of the other rusty engine tins, cylinder head covers, fan housing, brackets, etc... ![]() What is the best way to tackle all of these to restore them properly? Is a chemical bath a good way to go about it and efficient? I have someone that can do this locally but not sure if there is any concern about this? I was thinking of painting them after the bath with some rust prevention like a paint primer and then hitting with some coats of flat black paint or just rustoleoum paint. Any recommendations on what is the most efficient? or is elbow grease and some brushes the way to go? and any paint in specific you all have used? maybe for cooling purposes not that the engine tin should get that hot? thanks in advance! |
| 930cabman |
Jan 6 2026, 09:51 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,438 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
Many of us here are in the CSOB camp
some degreaser, elbow grease and Rustoleum will get er done |
| Nogoodwithusernames |
Jan 6 2026, 11:56 AM
Member ![]() ![]() Group: Members Posts: 299 Joined: 31-May 16 From: Sutter, CA Member No.: 20,051 Region Association: None |
Many of us here are in the CSOB camp some degreaser, elbow grease and Rustoleum will get er done If you go this route be sure to get the automotive paint, it is a little more expensive but gas and oil won't ruin your nice shiny new paint. https://www.homedepot.com/p/Rust-Oleum-Auto...52462/202623047 |
| TRP |
Jan 6 2026, 04:14 PM
Member ![]() ![]() Group: Members Posts: 175 Joined: 2-September 23 From: Morgan Hill, CA Member No.: 27,559 Region Association: None
Many of us here are in the CSOB camp some degreaser, elbow grease and Rustoleum will get er done If you go this route be sure to get the automotive paint, it is a little more expensive but gas and oil won't ruin your nice shiny new paint. https://www.homedepot.com/p/Rust-Oleum-Auto...52462/202623047 I am going through the same process right now for my 2056 build, I was thinking of using this paint for the tins: https://914rubber.com/engine-deck-lid-grill...2MDF5YOxYD1uTd0 ![]() What do you guys think? Thanks, Ted |
Aayala Engine Tin Restoration Jan 5 2026, 09:28 PM
mepstein Find a place to glass bead blast and powder coat. ... Jan 5 2026, 09:31 PM
Dlee6205
Find a place to glass bead blast and powder coat.... Jan 6 2026, 06:02 AM
Root_Werks
Find a place to glass bead blast and powder coat... Jan 7 2026, 10:01 AM
mepstein Either your machinist or your vapor hone person wi... Jan 6 2026, 07:17 AM
barefoot I went with a local sand blast outfit, then they e... Jan 6 2026, 09:14 AM
chmillman If you’re going to go with spray cans, I might l... Jan 6 2026, 04:25 PM
Chad911sc I restored all the tin and painted them myself. To... Jan 6 2026, 05:23 PM
mepstein You lost me at 3-4 days. Jan 6 2026, 06:14 PM
930cabman @Chad
does your wife know you baked engine tins ... Jan 6 2026, 06:18 PM
TRP
[b]@[url=http://www.914world.com/bbs2/index.php?s... Jan 6 2026, 06:21 PM
Chad911sc lol…I have been happily single for 12 years. How... Jan 7 2026, 06:40 AM
Aayala Awesome! Thank you for the recommendations y... Jan 7 2026, 08:55 AM
mepstein At my shop, that’s a couple hours of work and ma... Jan 7 2026, 11:53 AM
TRP I called around down here where I am located, to ... Jan 7 2026, 02:17 PM
wonkipop
I called around down here where I am located, to... Jan 7 2026, 03:03 PM
I called around down here where I am located, to... Jan 7 2026, 03:16 PM
TRP
I called around down here where I am located, t... Jan 7 2026, 03:52 PM![]() ![]() |
Lo-Fi Version | Time is now: 9th January 2026 - 09:45 AM |
