| Jgilliam914 |
Jan 4 2026, 12:48 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,374 Joined: 30-July 12 From: Iowa / Florida Member No.: 14,732 Region Association: Upper MidWest |
The last few times I bought them they were through EMPI
very light gauge metal and I would consider junk. One even had a pin hole in them Where is a good place to source quality one? TIA |
| TRP |
Jan 6 2026, 06:24 PM
Member ![]() ![]() Group: Members Posts: 170 Joined: 2-September 23 From: Morgan Hill, CA Member No.: 27,559 Region Association: None
Can the tubes and pushrods be replaced with motor in the car ? According to the google machine, Yes, you can replace pushrods and tubes on a Porsche 914 with the engine in the car, though it's tedious work requiring removal of valve covers, rockers, and heart exchangers (recommended), often needing some tubes to tilt or partially remove due to chassis clearance, and demanding careful reassembly with proper torque and seals to prevent major oil leaks. It's challenging but doable by working on one cylinder at a time, often with the engine raised or on tall jack stands. I give you this: http://www.914world.com/bbs2/lofiversion/i...php?t29951.html This feels like a question we could ask that new fancy 914world AI Agent. |
Jgilliam914 Push Rod Tube Source Jan 4 2026, 12:48 PM
Craigers17 The Type IV store sells billet aluminum, but they ... Jan 4 2026, 01:35 PM
mmichalik PMB has good push rod tubes as well: https://pmbp... Jan 4 2026, 03:43 PM
bdstone914 I have replated originals for $60 a set what... Jan 4 2026, 04:05 PM
porschetub
I have replated originals for $60 a set wha... Jan 4 2026, 07:23 PM
GregAmy I'm running Chris' stainless tubes and chr... Jan 4 2026, 06:07 PM
Jack Standz
PMB has good push rod tubes as well: https://pmb... Jan 5 2026, 06:16 AM
jim_hoyland Can the tubes and pushrods be replaced with motor ... Jan 6 2026, 05:53 PM
Jack Standz
Can the tubes and pushrods be replaced with motor... Jan 7 2026, 04:07 AM![]() ![]() |
Lo-Fi Version | Time is now: 8th January 2026 - 10:32 AM |
