> HEDALIGHT Disperate faulty, Unexpected fault
searunner
post Jan 4 2026, 12:23 PM
yesterday coming into my garage, I hear one ritming song- under the cover of my 914 2.0 1974, one strange movement, the LEFT Headlamp go UP and DOWN
The RIGHT Headlamp stays in the closed position.
Normally, I detach the battery of the car when in the garage, but I forgot this time.
The car was without a KEY IN - the Light switch was off -
The last trip with the car ALL was regular, and the headlamp was in working condition.
I can STOP the movement, detaching the battery- but this NO was the solution,
Then I searched for a better solution.
Extract completely the Light switch -(with the BATTERY connected and KEY ON) I have the two headlamps is up and in stable condition - also when I START the engine and move the car, and make a long trip
But if I return the light switch to the POSITION light, the LEFT Headlight return to UP_DOWN movement.
Is clear that I have one short- Or one Relay issue - BUT 914 was full of relays
Can someone help me, to return to a normal 914 ??
I am not a native English so overlook my errors
930cabman
post Jan 7 2026, 02:07 PM
(IMG:style_emoticons/default/idea.gif) Gremlins (IMG:style_emoticons/default/idea.gif)
searunner
post Jan 9 2026, 12:43 PM
QUOTE(930cabman @ Jan 7 2026, 02:07 PM) *
YES is a gremlin - I have tried one new relay, but the result was negative- the gremlin is [b]NOT THE RELAY - Probably the oldest is good, I have tested it and have the same results as the newer-
I must done two
1) On my car, I have modified the fog lamp to DAY LIGHT with Attached Imagetwo LED connected directly to the POSITION LIGHT -
My FOG SW is completely detached from the diagram.
2) The DRIVER Headlight is OK, follow all commands
The PASSENGER Headlight have this strange gremlins
This DIAGRAM can elucidate better: Passenger HEAD L. DRIVER HEAD L.
CAR BATTERY EXCLUDED DOWN DOWN
CAR BATTERY CONNECTED UP & DOWN immediately DOWN
KEY OFF UP&DOWN continue DOWN
KEY ON UP&DOWN continue DOWN
LIGHT SW ON -POSITION Light UP&DOWN continue DOWN
LIGHT SW ON -HEAD Light UP Light ON UP OK
LEVER control - ON Low Light UP Light ON UP OK
LEVER control - ON Head Light UP Light ON UP OK
[/b]So My 914 can be drive on the road only with the Head light on UP positionAttached Image
searunner   HEDALIGHT Disperate faulty   Jan 4 2026, 12:23 PM
TheCabinetmaker   I've had this exact problem. Mine happened in ...   Jan 4 2026, 04:17 PM
emerygt350   You mean the relays in the frunk? What a crazy is...   Jan 4 2026, 07:26 PM
ejm   Inside the headlight motors are switches that stop...   Jan 5 2026, 10:23 AM
Maltese Falcon   Inside the headlight motors are switches that sto...   Jan 5 2026, 06:03 PM
searunner   Good point ! I have cleaned these (internal di...   Jan 7 2026, 01:02 PM
emerygt350   Good point ! I have cleaned these (internal d...   Jan 7 2026, 02:00 PM
Spoke   Good point ! I have cleaned these (internal d...   Jan 17 2026, 01:41 PM
emerygt350   You can find these relays under the protective pla...   Jan 5 2026, 11:36 AM
930cabman   :idea: Gremlins :idea:   Jan 7 2026, 02:07 PM
searunner   :idea: Gremlins :idea: YES is a gremlin - I ha...   Jan 9 2026, 12:43 PM
searunner   The car photo was before the gremlins appeared The...   Jan 9 2026, 12:48 PM
Superhawk996   I’m afraid I’m really struggling with the lang...   Jan 9 2026, 01:35 PM
searunner   Many Thanks for the precious suggestion - I have n...   Jan 10 2026, 05:32 AM
searunner   One more understandable 914 GREMLINS FRAMEWORKS   Jan 11 2026, 04:16 AM
sixnotfour   https://www.pelicanparts.com/techarticles/9...u64T...   Jan 11 2026, 09:57 AM
searunner   Thanks - actually, I dismantle the Passenger Headl...   Jan 12 2026, 06:07 AM
searunner   The DIODE APPEARS good. (I test the PASSENGER SID...   Jan 15 2026, 12:35 PM
Superhawk996   The DIODE APPEARS good. (I test the PASSENGER SI...   Jan 15 2026, 07:59 PM
searunner   The DIODE APPEARS good. (I test the PASSENGER S...   Jan 16 2026, 05:56 AM
searunner   I forgot that in this condition, the TRIPLE Connec...   Jan 15 2026, 12:47 PM
Superhawk996   I forgot that in this condition, the TRIPLE Conne...   Jan 15 2026, 08:03 PM
Superhawk996   How about post #20 What happens removing the rel...   Jan 16 2026, 09:07 AM
emerygt350   How about post #20 What happens removing the re...   Jan 16 2026, 09:53 AM
Spoke   @emerygt350 [b]@[url=http://www.914world.com/bbs...   Jan 16 2026, 01:00 PM
Superhawk996   For the life of me I can't figure out what t...   Jan 16 2026, 05:58 PM
Spoke   For the life of me I can't figure out what ...   Jan 17 2026, 12:11 AM
Superhawk996   Question is would a dead or shorted diode cause t...   Jan 17 2026, 07:44 AM
Superhawk996   . Back to the original up/down issue, what are the...   Jan 17 2026, 07:58 AM
Superhawk996   What else could cause the down to skip right throu...   Jan 17 2026, 07:59 AM
searunner   [quote name='Spoke' post='3241147' date='Jan 17 2...   Jan 17 2026, 10:54 AM
Spoke   [quote name='Spoke' post='3241147' date='Jan 17 ...   Jan 17 2026, 01:04 PM
BeatNavy   FWIW, I had strange headlight behavior for years. ...   Jan 17 2026, 06:43 AM
Spoke   Changed the wheel to look a bit more like the actu...   Jan 17 2026, 10:52 AM
Superhawk996   Not sure I see a way to backfeed to the passenge...   Jan 17 2026, 12:48 PM
Spoke   [quote name='Spoke' post='3241215' date='Jan 17 2...   Jan 17 2026, 01:13 PM
searunner   I hypothesise that if I connect the LOT of the red...   Jan 17 2026, 12:11 PM
Superhawk996   I hypothesise that if I connect the LOT of the re...   Jan 17 2026, 12:49 PM
Superhawk996   So from post #32 we know that removing the passeng...   Jan 17 2026, 01:14 PM
Spoke   3) We need to figure out why the passenger side r...   Jan 17 2026, 02:26 PM
Superhawk996   Now do the the same with the headlamp switch in th...   Jan 17 2026, 01:19 PM
searunner   Now do the the same with the headlamp switch in t...   Jan 21 2026, 06:00 AM
searunner   After the last post, I never touched my 914. Yest...   Feb 9 2026, 05:19 AM
searunner   ONE MORE DEVELOPMENT After a lot of days of raini...   Feb 19 2026, 01:21 PM
- Lo-Fi Version Time is now: 22nd February 2026 - 05:47 PM
