> Fresh Air Blower, It worked on the bench
DennisV
post Jan 9 2026, 09:04 PM
The fresh air blower on our 1970 914-6 does not work. No air. No sound. No light.
Is operation of the fresh air blower dependent on anything other than:
1. battery
2. #8 fuse (15 amp windshield wipers, ventilator, horn, cigarette lighter)
3. sliding the lever on the dash
I am not seeing a relay listed on my wiring diagram or in the Workshop manual diagram of the engine bay relay board. There is no relay?
There is no associated switch? Just the slider?
My blower did not work. I pulled it and refurbed it. Bench tested working. Also cleaned the contact traces on the board with the sliders in the dash. Back in the car (after lots of cursing). Doesn’t work in the car (more cursing). (IMG:style_emoticons/default/mad.gif)
The horn works, so I know it's not the fuse. I unplugged and reseated the plug on the back of the blower.
I see a brown wire coming from the slider board. My diagram just says From: Male, To: ground instrument panel. So I'm not sure where it terminates.
Thank you.
tygaboy
post Jan 10 2026, 12:30 PM
I've been playing with the blower fan wiring on the Ferrari build and found that unless you are absolutely sure that the fan speed contacts REALLY are consistently in contact as they should be, the connection isn't reliable. In the case of the one I'm working with, it wasn't just cleaning things. The moving contact "arm" needed to be bent so it put more force downward as it moved through it's range and solidly touched the other contacts. I also added a bit of dielectric grease to all the contacts. That seems to have solved it for me.
DennisV
post Jan 10 2026, 08:19 PM
QUOTE(tygaboy @ Jan 10 2026, 10:30 AM) *
Thanks for sharing this Chris. Good to know.
Even with that in mind, once I jumped one of the speed wires to a ground on the chassis, shouldn't I have gotten something out of the blower?
3 User(s) are reading this topic (2 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 11th January 2026 - 09:15 AM
