| DennisV |
Jan 10 2026, 08:35 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,040 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California
Testing the windshield washer in our 1970 914-6. When I pull the wiper / washer lever I can hear a slight thud or click and then the wipers cycle. I have confirmed the noise is the electric pump as I can feel it move slightly if I put my hand on it while someone else pulls the lever. Does that mean the pump is good, or does a good working pump make a different noise?
I've been through many threads about the squirters not working, but haven't found much discussion about the electric pump itself. Thanks. |
| rgalla9146 |
Jan 11 2026, 07:04 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,998 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None
Original pumps are dated approximate to (but before) the cars manufacture date. I've had good luck disassembling, cleaning and reassembling them. Get the pump bracket and hardware plated while it's apart. |
DennisV Windshield Washer Electric Pump Jan 10 2026, 08:35 PM
Superhawk996 Should be a constant hum / whirring
Clunk / thun... Jan 10 2026, 08:53 PM
porschetub
Testing the windshield washer in our 1970 914-6. ... Jan 10 2026, 08:54 PM
johnhora DennisV....The pumps get gummed up inside and make... Jan 10 2026, 09:06 PM
DennisV
DennisV....The pumps get gummed up inside and mak... Jan 19 2026, 02:19 PM
914Sixer Clean the whole system if you have to take pump ap... Jan 11 2026, 07:30 AM
Cairo94507 Hey Dennis, great job on the washer motor video. ... Jan 20 2026, 08:01 AM
johnhora :agree: Nice informative video Dennis.. Jan 20 2026, 03:51 PM
NARP74 Nice video. The grease you used will wind up in t... Jan 20 2026, 05:04 PM
Steve Enlarged prostate? Jk.. I had to prime mine to g... Jan 20 2026, 08:49 PM
DennisV A related tip on this topic. The hoses are secured... Apr 6 2026, 02:00 PM
BillC
A related tip on this topic. The hoses are secure... Apr 6 2026, 04:06 PM
914Sixer Wire is NOT stock. Apr 6 2026, 06:49 PM
rgalla9146
Wire is NOT stock.
:agree:
fresh hose ... Apr 6 2026, 07:38 PM
DennisV
Wire is NOT stock.
:o
Thank you for pointing t... Apr 7 2026, 06:48 AM
aturboman As mentioned the original pumps have date markings... Apr 9 2026, 11:09 AM
DennisV
As mentioned the original pumps have date marking... May 26 2026, 05:04 AM
Superhawk996 Bench test rather than playing with it in car. Ai... May 26 2026, 11:05 AM
Cairo94507 I just spent the afternoon trying to sort my washe... Jul 7 2026, 04:08 PM
Cairo94507 Look what I found using the search function:
Jul 8 2026, 07:17 AM
Cairo94507 Jesus! This windshield washer system is makin... Jul 11 2026, 11:28 AM
DennisV
Jesus! This windshield washer system is maki... Jul 11 2026, 11:52 AM
Cairo94507 Dennis - I was able to use a couple of putty knife... Jul 11 2026, 05:07 PM
rgalla9146 The check valves at the squirters get stuck and wi... Jul 12 2026, 04:58 AM
wonkipop
The check valves at the squirters get stuck and w... Aug 21 2026, 06:52 PM
Cairo94507 Ohhhh, that is interesting. Stuck check valves ma... Jul 12 2026, 07:38 AM
DennisV
Ohhhh, that is interesting. Stuck check valves m... Aug 21 2026, 10:11 AM
Cairo94507 Hi Dennis,
What did you do to free up that valve i... Aug 21 2026, 02:47 PM
DennisV
Hi Dennis,
What did you do to free up that valve ... Aug 21 2026, 02:52 PM
jim_hoyland Had the same issue. I removed the vent cap and dri... Aug 21 2026, 07:20 PM
wonkipop looking at parts diagram above and made me think.
... Aug 21 2026, 08:07 PM![]() ![]() |
Lo-Fi Version | Time is now: 22nd October 2026 - 01:45 PM |
