| Geezer914 |
Jan 14 2026, 11:55 AM
Geezer914 ![]() ![]() ![]() ![]() Group: Members Posts: 2,185 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States
75 914 2056, Ljet EFI. Pulled the engine to fix an oil leak. Everything back together, engine starts and dies. Checked fuel pressure, gauge reads 30 lbs. Ignition is a Mallory Unilite. (IMG:style_emoticons/default/confused24.gif)
| sixnotfour |
Jan 14 2026, 12:52 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,092 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains
reach in open the air flapper door by hand..see if it stays running
| fiacra |
Jan 14 2026, 05:08 PM
Person.Woman.Man.Camera.TV. = MCI ![]() ![]() ![]() Group: Members Posts: 673 Joined: 1-March 19 From: East Bay Region - California Member No.: 22,920 Region Association: Northern California
reach in open the air flapper door by hand..see if it stays running Probably not covering ground you haven't thought of, but I would go back and re-touch everything you d/c when you pulled the engine, or anything that might have gotten knocked loose. Loose or intermittent connection is where I would be focusing my attention. I agree with checking function of the dual relay (manually opening the flapper door) and then, if needed, directly checking the relay. It would be an odd coincidence to have it go out right at the time you pull the engine. These are getting hard to come by again, but JBugs and CIP1 currently show them as being in stock. Unfortunately they cost nearly twice as much as they used to because of tariffs. |
Geezer914 Engine catches then dies. Jan 14 2026, 11:55 AM
Jack Standz Have loved Mallory Unilite distributors for many y... Jan 14 2026, 12:26 PM![]() ![]() |
Lo-Fi Version | Time is now: 15th January 2026 - 02:47 AM |
