| searunner |
Jan 4 2026, 12:23 PM
Newbie ![]() Group: Members Posts: 32 Joined: 8-January 20 From: italy Member No.: 23,809 Region Association: None |
yesterday coming into my garage, I hear one ritming song- under the cover of my 914 2.0 1974, one strange movement, the LEFT Headlamp go UP and DOWN
The RIGHT Headlamp stays in the closed position. Normally, I detach the battery of the car when in the garage, but I forgot this time. The car was without a KEY IN - the Light switch was off - The last trip with the car ALL was regular, and the headlamp was in working condition. I can STOP the movement, detaching the battery- but this NO was the solution, Then I searched for a better solution. Extract completely the Light switch -(with the BATTERY connected and KEY ON) I have the two headlamps is up and in stable condition - also when I START the engine and move the car, and make a long trip But if I return the light switch to the POSITION light, the LEFT Headlight return to UP_DOWN movement. Is clear that I have one short- Or one Relay issue - BUT 914 was full of relays Can someone help me, to return to a normal 914 ?? I am not a native English so overlook my errors |
| searunner |
Jan 15 2026, 12:47 PM
I forgot that in this condition, the TRIPLE Connector(Passenger side HeadLight)
The RED wire sends electrical power. Detaching it all STOPS |
searunner HEDALIGHT Disperate faulty Jan 4 2026, 12:23 PM
TheCabinetmaker I've had this exact problem. Mine happened in ... Jan 4 2026, 04:17 PM
emerygt350 You mean the relays in the frunk? What a crazy is... Jan 4 2026, 07:26 PM
ejm Inside the headlight motors are switches that stop... Jan 5 2026, 10:23 AM
Maltese Falcon
Inside the headlight motors are switches that sto... Jan 5 2026, 06:03 PM
searunner Good point ! I have cleaned these (internal di... Jan 7 2026, 01:02 PM
emerygt350
Good point ! I have cleaned these (internal d... Jan 7 2026, 02:00 PM
Spoke
Good point ! I have cleaned these (internal d... Jan 17 2026, 01:41 PM
emerygt350 You can find these relays under the protective pla... Jan 5 2026, 11:36 AM
930cabman :idea: Gremlins :idea: Jan 7 2026, 02:07 PM
searunner
YES is a gremlin - I ha... Jan 9 2026, 12:43 PM
searunner The car photo was before the gremlins appeared
The... Jan 9 2026, 12:48 PM
Superhawk996 I’m afraid I’m really struggling with the lang... Jan 9 2026, 01:35 PM
searunner Many Thanks for the precious suggestion -
I have n... Jan 10 2026, 05:32 AM
searunner One more understandable 914 GREMLINS FRAMEWORKS Jan 11 2026, 04:16 AM
sixnotfour https://www.pelicanparts.com/techarticles/9...u64T... Jan 11 2026, 09:57 AM
searunner Thanks - actually, I dismantle the Passenger Headl... Jan 12 2026, 06:07 AM
searunner The DIODE APPEARS good. (I test the PASSENGER SID... Jan 15 2026, 12:35 PM
Superhawk996
The DIODE APPEARS good. (I test the PASSENGER SI... Jan 15 2026, 07:59 PM
searunner
The DIODE APPEARS good. (I test the PASSENGER S... Jan 16 2026, 05:56 AM
Superhawk996
I forgot that in this condition, the TRIPLE Conne... Jan 15 2026, 08:03 PM
Superhawk996 How about post #20
What happens removing the rel... Jan 16 2026, 09:07 AM
emerygt350
How about post #20
What happens removing the re... Jan 16 2026, 09:53 AM
Spoke @emerygt350
[b]@[url=http://www.914world.com/bbs... Jan 16 2026, 01:00 PM
Superhawk996
For the life of me I can't figure out what t... Jan 16 2026, 05:58 PM
Spoke
For the life of me I can't figure out what ... Jan 17 2026, 12:11 AM
Superhawk996 Question is would a dead or shorted diode cause t... Jan 17 2026, 07:44 AM
Superhawk996 . Back to the original up/down issue, what are the... Jan 17 2026, 07:58 AM
Superhawk996 What else could cause the down to skip right throu... Jan 17 2026, 07:59 AM
searunner
[quote name='Spoke' post='3241147' date='Jan 17 2... Jan 17 2026, 10:54 AM
Spoke
[quote name='Spoke' post='3241147' date='Jan 17 ... Jan 17 2026, 01:04 PM
BeatNavy FWIW, I had strange headlight behavior for years. ... Jan 17 2026, 06:43 AM
Spoke Changed the wheel to look a bit more like the actu... Jan 17 2026, 10:52 AM
Superhawk996
Not sure I see a way to backfeed to the passenge... Jan 17 2026, 12:48 PM
Spoke
[quote name='Spoke' post='3241215' date='Jan 17 2... Jan 17 2026, 01:13 PM
searunner I hypothesise that if I connect the LOT of the red... Jan 17 2026, 12:11 PM
Superhawk996
I hypothesise that if I connect the LOT of the re... Jan 17 2026, 12:49 PM
Superhawk996 So from post #32 we know that removing the passeng... Jan 17 2026, 01:14 PM
Spoke
3) We need to figure out why the passenger side r... Jan 17 2026, 02:26 PM
Superhawk996 Now do the the same with the headlamp switch in th... Jan 17 2026, 01:19 PM
searunner
Now do the the same with the headlamp switch in t... Jan 21 2026, 06:00 AM
searunner After the last post, I never touched my 914.
Yest... Feb 9 2026, 05:19 AM
searunner ONE MORE DEVELOPMENT
After a lot of days of raini... Feb 19 2026, 01:21 PM![]() ![]() |
Lo-Fi Version | Time is now: 22nd February 2026 - 05:42 PM |
