| mcericmc |
Jan 15 2026, 12:25 PM
Newbie ![]() Group: Members Posts: 13 Joined: 30-June 21 From: Texas Member No.: 25,681 Region Association: None |
There is only one timing mark on my 1.8 fan. It's visible through a notch on the rear side of the fan via the inspection port. Pelican parts info says the mark is TDC. Auto Atlanta says it's 7.5 degrees BTDC in the 914 tech tips 700 book. Can someone please tell me which is correct? I need to make sure the timing and valves are adjusted properly. (IMG:style_emoticons/default/WTF.gif)
| Jack Standz |
Jan 15 2026, 06:38 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 735 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None
Ok, here's a follow-up to my previous attempt to post information on how to figure out where Top Dead Center (TDC) for cylinder #1 is on your motor. Please note that when timing the motor it is important to understand the difference between TDC when cylinder #1 is on its compression stroke versus the exhaust stroke.
You only need the TDC fan marking for valve adjustments and ignition timing. Any other marks on the fan or flywheel aren't needed. It doesn't matter if it's an ljet fan, djet fan, a bus fan, a 411/412 fan, etc. Take a marker, white paint or even a crayon. If there isn't a mark there already, put a mark in the middle of fin #6 and fin #7 (TDC is actually a tiny bit closer to fin #6 than fin #7, if that matters to you). That's close enough to TDC for #1 cylinder to perform valve adjustments and set your timing. Even though a standard timing light can be used, strongly encourage using a dial back timing Iight. Additional instructions start at the third post: https://www.thesamba.com/vw/forum/viewtopic.php?t=699839 |
| mcericmc |
Jan 15 2026, 10:20 PM
Thanks for the info.
mcericmc 1.8 engine timing mark Jan 15 2026, 12:25 PM
930cabman :wttc:
wish I could be of assistance, but I have... Jan 15 2026, 01:56 PM
Jack Standz Photo Jan 15 2026, 02:04 PM
wonkipop
thats a D Jet fan - its different to the ... Jan 15 2026, 04:08 PM
mcericmc Thanks. I think your right. What REALLY confused m... Jan 15 2026, 04:47 PM
emerygt350 I would always establish tdc regardless of what th... Jan 15 2026, 04:51 PM
Ninja Just adding verification...
I too, was perplexed ... Jan 15 2026, 07:58 PM
ClayPerrine
I too, was perplexed... Jan 18 2026, 08:06 AM
mjrrti There should be a notch in your flywheel that can ... Jan 15 2026, 11:34 PM
wonkipop
There should be a notch in your flywheel that can... Jan 18 2026, 09:49 PM
Jack Standz You are correct. That's how you time a stock ... Jan 18 2026, 12:23 PM
Jack Standz We had a 1.8 liter ljet motor in a 914 (now replac... Jan 18 2026, 11:27 PM
wonkipop
We had a 1.8 liter ljet motor in a 914 (now repla... Jan 19 2026, 01:09 AM![]() ![]() |
Lo-Fi Version | Time is now: 17th March 2026 - 05:46 PM |
