> HEDALIGHT Disperate faulty, Unexpected fault
searunner
post Jan 4 2026, 12:23 PM
yesterday coming into my garage, I hear one ritming song- under the cover of my 914 2.0 1974, one strange movement, the LEFT Headlamp go UP and DOWN
The RIGHT Headlamp stays in the closed position.
Normally, I detach the battery of the car when in the garage, but I forgot this time.
The car was without a KEY IN - the Light switch was off -
The last trip with the car ALL was regular, and the headlamp was in working condition.
I can STOP the movement, detaching the battery- but this NO was the solution,
Then I searched for a better solution.
Extract completely the Light switch -(with the BATTERY connected and KEY ON) I have the two headlamps is up and in stable condition - also when I START the engine and move the car, and make a long trip
But if I return the light switch to the POSITION light, the LEFT Headlight return to UP_DOWN movement.
Is clear that I have one short- Or one Relay issue - BUT 914 was full of relays
Can someone help me, to return to a normal 914 ??
I am not a native English so overlook my errors
Spoke
post Jan 16 2026, 01:00 PM
Jerry
@emerygt350
@Superhawk996
Here is the basic schematic for the headlight motors. This is from a Haynes manual. Not sure I understand how the switches in the motor are configured. Are they switches riding on a cam or slide contacts on a PCB wheel?
The headlight switch is shown in the PARKING position where both UP and DOWN contacts are open. The headlight position is 1/2 up/down and both switches are closed. Both motors are off.
If in the DOWN position, the headlight switch provides power to the DOWN switch which is closed and the motor cycles until the cam/PCB wheel opens the DOWN switch.
If in the UP position, the same thing happens except the motor stops in the UP position.
Notice the headlight switch is not fused according to Haynes. Yikes!
For the life of me I can't figure out what the diodes do. Assuming they minimize interaction between the 2 motors but I can't figure it out.
For the issue for @searunner where the motor stops at UP but cycles up/down on DOWN, the switch in the motor for DOWN is not opening up. If the relay was sticking on, it would stick on for UP too.
Superhawk996
post Jan 16 2026, 05:58 PM
QUOTE(Spoke @ Jan 16 2026, 03:00 PM) *
Not sure what you mean. You have it correct.
Since the headlamp motors cannot be synchronized, the diodes block current flow between the UP & Down circuits during the period when the rotary switch would otherwise allow continuity between those circuits when they are between fully up or fully down.
The way the Haynes manual shows the rotary switch matches its physical layout.
Picture below ( @georgekopf ) photos
Spoke
post Jan 17 2026, 12:11 AM
Jerry
QUOTE(Superhawk996 @ Jan 16 2026, 06:58 PM) *
OK I see what the diodes do. Question is would a dead or shorted diode cause the up/down observed?
Thanks for the pictures. I didn't think there were switches in there. Back to the original up/down issue, what are the chances that there's metallic build up on the insulator for the down wiper? What else could cause the down to skip right through the stop to cycle again?
Superhawk996
post Jan 17 2026, 07:59 AM
QUOTE(Spoke @ Jan 17 2026, 02:11 AM) *
Shorts in the wiring itself.
I suspect this is the more likely scenario for the OP.
Two problems with my internally shorted diode scenario.
1) Diodes usually fail open. In that case, the up or down function just doesn’t work.
2) When the driver side motor goes to the down position it should open the down rotary switch which itself would keep the current from reverse flowing through to D4. So although the wonky up/down on the passenger side can occur when lights are between fully up/down, it would eventually resolve itself after a few cycles and should not continue indefinitely. For the behavior to continue indefinitely, there would have to be a dual failure of both D4 and the passenger side rotary down switch. Not impossible but not likely either.
searunner
post Jan 17 2026, 10:54 AM
QUOTE(Superhawk996 @ Jan 17 2026, 07:59 AM) *
FIRST, Thanks for HELP
Today I did the Test with and without the Relays
I reconnect the RED wire to the 3 Connector HLight
BATTERY OFF
Passenger HLamp DOWN---------------------------------Driver HLamp DOWN
BATTERY ON
Passenger HL UP & DOWN -continue-------------Driver HLamp DOWN NO Move
RELAY Passenger OFF STOP Movement------------------Driver HLamp DOWN NO Move
RELAY Passenger IN UP&DOWN restart----------------Driver HLamp DOWN NO Move
RELAY DRIVER OFF DOWN NO MOVE-- Passenger HL UP & DOWN -continue- ---------next I have reconnected the relay on the Driver side
CAR KEY ON
-------- Passenger HL UP & DOWN -continue --------- Driver HLamp DOWN NO Move
SWTCH LIGHT in Position Light
----------Passenger HL UP & DOWN -continue ----------Driver HLamp DOWN NO Move
SWICH LIGT turned to KIGH Light
----------Passenger UP stable------------------------------Driver UP stable
I can go on the road with the TWO DAYLIGHTS that are connected with the POSITION light
or with all TWO HLamp UP with SW Light on KIGH Light position -
The Problem is that I must disconnect the Passenger RED wire.
I have the Head lamp passenger UP& DAWN immediately when the BATTERY is connacted.
Spoke
post Jan 17 2026, 01:04 PM
Jerry
QUOTE(searunner @ Jan 17 2026, 11:54 AM) *
BATTERY OFF
BATTERY ON
CAR KEY ON
Thanks for the information. Yes you can drive your 914 with lights on. If you have to stop the engine if you change the headlights to 'parking' the headlights will be off and the pass motor will not cycle.
What you observe seems consistent with our thoughts that the pass side relay is not releasing for headlights OFF.
searunner   HEDALIGHT Disperate faulty   Jan 4 2026, 12:23 PM
TheCabinetmaker   I've had this exact problem. Mine happened in ...   Jan 4 2026, 04:17 PM
emerygt350   You mean the relays in the frunk? What a crazy is...   Jan 4 2026, 07:26 PM
ejm   Inside the headlight motors are switches that stop...   Jan 5 2026, 10:23 AM
Maltese Falcon   Inside the headlight motors are switches that sto...   Jan 5 2026, 06:03 PM
searunner   Good point ! I have cleaned these (internal di...   Jan 7 2026, 01:02 PM
emerygt350   Good point ! I have cleaned these (internal d...   Jan 7 2026, 02:00 PM
Spoke   Good point ! I have cleaned these (internal d...   Jan 17 2026, 01:41 PM
emerygt350   You can find these relays under the protective pla...   Jan 5 2026, 11:36 AM
930cabman   :idea: Gremlins :idea:   Jan 7 2026, 02:07 PM
searunner   :idea: Gremlins :idea: YES is a gremlin - I ha...   Jan 9 2026, 12:43 PM
searunner   The car photo was before the gremlins appeared The...   Jan 9 2026, 12:48 PM
Superhawk996   I’m afraid I’m really struggling with the lang...   Jan 9 2026, 01:35 PM
searunner   Many Thanks for the precious suggestion - I have n...   Jan 10 2026, 05:32 AM
searunner   One more understandable 914 GREMLINS FRAMEWORKS   Jan 11 2026, 04:16 AM
sixnotfour   https://www.pelicanparts.com/techarticles/9...u64T...   Jan 11 2026, 09:57 AM
searunner   Thanks - actually, I dismantle the Passenger Headl...   Jan 12 2026, 06:07 AM
searunner   The DIODE APPEARS good. (I test the PASSENGER SID...   Jan 15 2026, 12:35 PM
Superhawk996   The DIODE APPEARS good. (I test the PASSENGER SI...   Jan 15 2026, 07:59 PM
searunner   The DIODE APPEARS good. (I test the PASSENGER S...   Jan 16 2026, 05:56 AM
searunner   I forgot that in this condition, the TRIPLE Connec...   Jan 15 2026, 12:47 PM
Superhawk996   I forgot that in this condition, the TRIPLE Conne...   Jan 15 2026, 08:03 PM
Superhawk996   How about post #20 What happens removing the rel...   Jan 16 2026, 09:07 AM
emerygt350   How about post #20 What happens removing the re...   Jan 16 2026, 09:53 AM
Spoke   @emerygt350 [b]@[url=http://www.914world.com/bbs...   Jan 16 2026, 01:00 PM
Superhawk996   For the life of me I can't figure out what t...   Jan 16 2026, 05:58 PM
Spoke   For the life of me I can't figure out what ...   Jan 17 2026, 12:11 AM
Superhawk996   Question is would a dead or shorted diode cause t...   Jan 17 2026, 07:44 AM
Superhawk996   . Back to the original up/down issue, what are the...   Jan 17 2026, 07:58 AM
Superhawk996   What else could cause the down to skip right throu...   Jan 17 2026, 07:59 AM
searunner   [quote name='Spoke' post='3241147' date='Jan 17 2...   Jan 17 2026, 10:54 AM
Spoke   [quote name='Spoke' post='3241147' date='Jan 17 ...   Jan 17 2026, 01:04 PM
BeatNavy   FWIW, I had strange headlight behavior for years. ...   Jan 17 2026, 06:43 AM
Spoke   Changed the wheel to look a bit more like the actu...   Jan 17 2026, 10:52 AM
Superhawk996   Not sure I see a way to backfeed to the passenge...   Jan 17 2026, 12:48 PM
Spoke   [quote name='Spoke' post='3241215' date='Jan 17 2...   Jan 17 2026, 01:13 PM
searunner   I hypothesise that if I connect the LOT of the red...   Jan 17 2026, 12:11 PM
Superhawk996   I hypothesise that if I connect the LOT of the re...   Jan 17 2026, 12:49 PM
Superhawk996   So from post #32 we know that removing the passeng...   Jan 17 2026, 01:14 PM
Spoke   3) We need to figure out why the passenger side r...   Jan 17 2026, 02:26 PM
Superhawk996   Now do the the same with the headlamp switch in th...   Jan 17 2026, 01:19 PM
searunner   Now do the the same with the headlamp switch in t...   Jan 21 2026, 06:00 AM
searunner   After the last post, I never touched my 914. Yest...   Feb 9 2026, 05:19 AM
searunner   ONE MORE DEVELOPMENT After a lot of days of raini...   Feb 19 2026, 01:21 PM
- Lo-Fi Version Time is now: 22nd February 2026 - 05:42 PM
