| Chad911sc |
Jan 17 2026, 10:26 AM
Member ![]() ![]() Group: Members Posts: 328 Joined: 24-September 24 From: Florida Member No.: 28,374 Region Association: South East States |
So my plan was to start assembling the 2056 today, but I found this when placing the oil pump into the case. I measured the gap needed to fill with a gasket, and it’s right at 3mm. Do they make a thick pump to case gasket that will fill this space, so that the rubber sealing ring will be in the case instead of hanging out the back of it??
The gaskets that came with the pump are way to thin to place the pump in the correct position. Attached thumbnail(s) |
| Chad911sc |
Jan 17 2026, 05:26 PM
So the pump body is definitely too long. It’s just shy of 2mm longer than the previous pump that came out of the running motor. I have sent pictures and explanation to the company I bought it from. The boss on the back of the pump where the gear engages the cam gear is also a hair longer as well. It bottoms out against the cam as you can see in the first pic.
Chad911sc Thick oil pump gasket Jan 17 2026, 10:26 AM
fixer34 I don't think you should need a 3mm thick gask... Jan 17 2026, 02:30 PM
Geezer914 Check the clearance to the cam gear with the cam i... Jan 17 2026, 02:40 PM
Montreal914 That groove tawards the inside doesn't look li... Jan 17 2026, 03:03 PM
Ninja I'd check the line up of the oil pump ports to... Jan 17 2026, 04:59 PM
porschetub
So the pump body is definitely too long. It’s j... Jan 18 2026, 02:54 PM
Chad911sc Yes, I think I will be ok using the non o-ringed p... Jan 19 2026, 09:40 AM
Jack Standz Gene Berg still makes o-ringed type 1 oil pumps (h... Jan 19 2026, 10:39 AM
Chad911sc I looked on the Gene Berg site earlier today becau... Jan 19 2026, 11:46 AM
stownsen914 I've understood that type 1 pumps require mach... Jan 20 2026, 08:17 AM
Chad911sc So I called Gene Berg today and talked to their te... Jan 20 2026, 12:06 PM
Superhawk996 SMH.
This commentary isn’t directed at the OP ... Jan 20 2026, 12:40 PM
friethmiller
Moral of the story: if you have a decent T4 pump... Jan 20 2026, 01:11 PM
Superhawk996
[quote name='Superhawk996' post='3241638' date='J... Jan 20 2026, 01:20 PM
Jack Standz Generally, modifying a type 1 oil pump (please not... Jan 20 2026, 01:27 PM
Jack Standz Or use a good type iv oil pump and pin the shaft l... Jan 20 2026, 01:32 PM
Jack Standz
[quote name='Superhawk996' post='3241638' date='... Jan 20 2026, 01:34 PM
Geezer914 Oil pressure on a T4 pump compared to a 26mm T1 pu... Jan 20 2026, 03:58 PM![]() ![]() |
Lo-Fi Version | Time is now: 23rd November 2026 - 02:27 PM |
