| Chaznaster |
Jan 20 2026, 06:31 PM
Member ![]() ![]() Group: Members Posts: 341 Joined: 22-November 15 From: Concord, MA Member No.: 19,389 Region Association: North East States
Hi.
I am planning to address the grinding I get when going into 1st gear at anything faster than a full stop. The Pelican article on the replacing first gear seems pretty good, and I plan to search these pages for nuggets of wisdom before starting. This thing has been grinding as long as I have had it and certainly long before that ... so I figure it is in pretty bad shape. Pelican suggests the following parts: slider, shift fork, synchro ring and brake band, dog teeth, and maybe first gear if it is worn. I plan to open it up before getting parts - and I assume they are all available without much trouble. I'd appreciate your thoughts on tackling this project as well as any advice. Thanks. Christian |
mgphoto
Hi.
I am planning to address the grinding I get... Jan 20 2026, 07:09 PM
Dave_Darling
You do know there isn’t any syncro from 2nd to ... Jan 21 2026, 02:22 AM
brant
You do know there isn’t any syncro from 2nd to... Jan 21 2026, 08:06 AM
ctc911ctc
You do know there isn’t any syncro from 2nd to... Jan 21 2026, 12:39 PM
rfinegan Dr Evil may have some of the parts both new or us... Jan 20 2026, 07:38 PM
mepstein My experience, after rebuilding a couple dozen tra... Jan 20 2026, 07:39 PM
914werke Hi. I am planning to address the grinding I get w... Jan 21 2026, 10:05 AM
Ninja
Dr Evil may have some of the parts both new or u... Jan 21 2026, 10:05 AM
mgphoto Has anyone on this board ever down shifted from 30... Jan 21 2026, 12:39 PM
ctc911ctc The difference in gear-spin is pretty severe at th... Jan 21 2026, 12:53 PM
brant
Has anyone on this board ever down shifted from 3... Jan 21 2026, 12:56 PM
Dave_Darling
Has anyone on this board ever down shifted from 3... Jan 23 2026, 02:49 AM
mgphoto Please observe parts 41, 8 and 9. Syncro only on o... Jan 21 2026, 12:46 PM
ctc911ctc You may find this helpful: http://www.914world.co... Jan 21 2026, 12:50 PM
Jack Standz
Please observe parts 41, 8 and 9. Syncro only on ... Jan 21 2026, 03:06 PM
ctc911ctc 43 is $$$$$
Dr. Evil sol... Jan 21 2026, 03:18 PM
dr914@autoatlanta.com easily done with the transmission in the car, just... Jan 21 2026, 03:47 PM
Jack Standz
43 is $$$$$
Dr. Evil so... Jan 21 2026, 04:15 PM
Chaznaster I've been away from this forum for some time (... Jan 21 2026, 06:30 PM
worn
I am going to try to it with the trans in the car... Jan 21 2026, 07:12 PM
targa72e I have read in some other post about getting 1st g... Jan 21 2026, 10:57 PM
rfinegan A little sneak peak of what is involved: youtube l... Jan 22 2026, 08:38 AM
Chaznaster
A little sneak peak of what is involved: youtube ... Jan 22 2026, 07:32 PM
Chaznaster I finally found some time to tear into the transmi... Feb 15 2026, 02:43 PM
mepstein If first gear is gone, second is usually close beh... Feb 15 2026, 03:09 PM
ctc911ctc
If first gear is gone, second is usually close be... Feb 16 2026, 03:31 PM
mlindner I do have the tools needed for a small rental fee.... Feb 15 2026, 03:43 PM
jim_hoyland :) Nice pics, thanks for posting Feb 15 2026, 04:03 PM
914werke Sucker is toast
Feb 16 2026, 12:25 PM
rudedude If you haven't spend some time on the bird sit... Feb 16 2026, 02:40 PM
Chaznaster Thanks to all for the confirmation and advice.
I ... Feb 16 2026, 05:40 PM
ctc911ctc Sent you a pm
Thanks to all for the confirmati... Feb 16 2026, 06:42 PM
Chaznaster Today I separated the dog teeth and pressed in the... Mar 1 2026, 02:21 PM
Ninja You might have gotten lucky! :ninja:
Finding ... Mar 1 2026, 03:51 PM
brant Zzz you’re half way there and you have the video... Mar 1 2026, 04:12 PM
Chaznaster I am going to go for it. Will report back! Mar 5 2026, 07:20 PM
Chaznaster So I finally got around to dropping the engine in ... Mar 30 2026, 05:30 PM
Montreal914 Not familiar with the tangerine plate but the cros... Mar 30 2026, 06:25 PM
Chaznaster The transmission is off the engine. That was easie... Apr 6 2026, 06:22 PM
Montreal914 :) :smash: :driving:
Apr 6 2026, 08:39 PM
Chaznaster
Thanks. I had be... Apr 7 2026, 05:25 PM
rudedude Need a good 8mm triple square to remove the bolts.... Apr 7 2026, 07:44 AM
Montreal914 Unfortunately I do not. Numbers gets superceded. ... Apr 7 2026, 11:27 PM
Chaznaster I pulled the stack today. The 3 dog teeth and slid... Apr 14 2026, 05:15 PM
Chaznaster I got to some disassembly today and have questions... Apr 18 2026, 02:35 PM
Jack Standz To answer your question:
"For 2 and 3 gear ... Apr 18 2026, 03:20 PM
Chaznaster I got the rest disassembled this morning.
Synchr... Apr 19 2026, 07:57 AM
ctc911ctc Dog Teeth's job is to avoid lock-ups but can b... Apr 19 2026, 08:03 PM
Chaznaster Excellent news to report!
I finished the reb... May 25 2026, 05:15 PM
BillC
I finished the re... May 26 2026, 12:00 PM
Dr Evil
I finished the re... Jun 3 2026, 08:21 AM
Jack Standz :driving: May 26 2026, 12:40 AM
craig downs I've read never downshift into 1st May 29 2026, 08:28 PM
Dr Evil
You are c... Jun 3 2026, 08:20 AM
mgphoto
You are ... Jun 4 2026, 09:14 AM
dtmehall i've done it for 53 years! (carefully) May 29 2026, 08:31 PM
Chaznaster I certainly do not downshift to first at high spee... May 30 2026, 09:34 AM
Chaznaster Thanks for the tip.
I had always gone into first ... Jun 7 2026, 06:31 PM![]() ![]() |
Lo-Fi Version | Time is now: 22nd November 2026 - 03:17 PM |
