| Chaznaster |
Jan 20 2026, 06:31 PM
Member ![]() ![]() Group: Members Posts: 341 Joined: 22-November 15 From: Concord, MA Member No.: 19,389 Region Association: North East States
Hi.
I am planning to address the grinding I get when going into 1st gear at anything faster than a full stop. The Pelican article on the replacing first gear seems pretty good, and I plan to search these pages for nuggets of wisdom before starting. This thing has been grinding as long as I have had it and certainly long before that ... so I figure it is in pretty bad shape. Pelican suggests the following parts: slider, shift fork, synchro ring and brake band, dog teeth, and maybe first gear if it is worn. I plan to open it up before getting parts - and I assume they are all available without much trouble. I'd appreciate your thoughts on tackling this project as well as any advice. Thanks. Christian |
| mgphoto |
Jan 20 2026, 07:09 PM
"If there is a mistake it will find me" ![]() ![]() ![]() Group: Members Posts: 1,512 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
Hi. I am planning to address the grinding I get when going into 1st gear at anything faster than a full stop. The Pelican article on the replacing first gear seems pretty good, and I plan to search these pages for nuggets of wisdom before starting. This thing has been grinding as long as I have had it and certainly long before that ... so I figure it is in pretty bad shape. Pelican suggests the following parts: slider, shift fork, synchro ring and brake band, dog teeth, and maybe first gear if it is worn. I plan to open it up before getting parts - and I assume they are all available without much trouble. I'd appreciate your thoughts on tackling this project as well as any advice. Thanks. Christian You do know there isn’t any syncro from 2nd to first, you basically have to let the gears mesh up to shift. |
| Dave_Darling |
Jan 21 2026, 02:22 AM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,367 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
You do know there isn’t any syncro from 2nd to first, you basically have to let the gears mesh up to shift. That is incorrect, there is a synchro on 1st gear. In stock form, it's a different one from the others, but any of the other synchros can be used as long as you use the other parts (e.g., the stop blocks and maybe other stuff) that go with them. A number of old cars do not have synchros on first gear. AFAIK, all Porsches have always had 1st gear synchros. (Possibly some very early 356es did not, but the later ones did!) --DD |
Chaznaster Synchro Replacement Jan 20 2026, 06:31 PM
brant
You do know there isn’t any syncro from 2nd to... Jan 21 2026, 08:06 AM
ctc911ctc
You do know there isn’t any syncro from 2nd to... Jan 21 2026, 12:39 PM
rfinegan Dr Evil may have some of the parts both new or us... Jan 20 2026, 07:38 PM
mepstein My experience, after rebuilding a couple dozen tra... Jan 20 2026, 07:39 PM
914werke Hi. I am planning to address the grinding I get w... Jan 21 2026, 10:05 AM
Ninja
Dr Evil may have some of the parts both new or u... Jan 21 2026, 10:05 AM
mgphoto Has anyone on this board ever down shifted from 30... Jan 21 2026, 12:39 PM
ctc911ctc The difference in gear-spin is pretty severe at th... Jan 21 2026, 12:53 PM
brant
Has anyone on this board ever down shifted from 3... Jan 21 2026, 12:56 PM
Dave_Darling
Has anyone on this board ever down shifted from 3... Jan 23 2026, 02:49 AM
mgphoto Please observe parts 41, 8 and 9. Syncro only on o... Jan 21 2026, 12:46 PM
ctc911ctc You may find this helpful: http://www.914world.co... Jan 21 2026, 12:50 PM
Jack Standz
Please observe parts 41, 8 and 9. Syncro only on ... Jan 21 2026, 03:06 PM
ctc911ctc 43 is $$$$$
Dr. Evil sol... Jan 21 2026, 03:18 PM
dr914@autoatlanta.com easily done with the transmission in the car, just... Jan 21 2026, 03:47 PM
Jack Standz
43 is $$$$$
Dr. Evil so... Jan 21 2026, 04:15 PM
Chaznaster I've been away from this forum for some time (... Jan 21 2026, 06:30 PM
worn
I am going to try to it with the trans in the car... Jan 21 2026, 07:12 PM
targa72e I have read in some other post about getting 1st g... Jan 21 2026, 10:57 PM
rfinegan A little sneak peak of what is involved: youtube l... Jan 22 2026, 08:38 AM
Chaznaster
A little sneak peak of what is involved: youtube ... Jan 22 2026, 07:32 PM
Chaznaster I finally found some time to tear into the transmi... Feb 15 2026, 02:43 PM
mepstein If first gear is gone, second is usually close beh... Feb 15 2026, 03:09 PM
ctc911ctc
If first gear is gone, second is usually close be... Feb 16 2026, 03:31 PM
mlindner I do have the tools needed for a small rental fee.... Feb 15 2026, 03:43 PM
jim_hoyland :) Nice pics, thanks for posting Feb 15 2026, 04:03 PM
914werke Sucker is toast
Feb 16 2026, 12:25 PM
rudedude If you haven't spend some time on the bird sit... Feb 16 2026, 02:40 PM
Chaznaster Thanks to all for the confirmation and advice.
I ... Feb 16 2026, 05:40 PM
ctc911ctc Sent you a pm
Thanks to all for the confirmati... Feb 16 2026, 06:42 PM
Chaznaster Today I separated the dog teeth and pressed in the... Mar 1 2026, 02:21 PM
Ninja You might have gotten lucky! :ninja:
Finding ... Mar 1 2026, 03:51 PM
brant Zzz you’re half way there and you have the video... Mar 1 2026, 04:12 PM
Chaznaster I am going to go for it. Will report back! Mar 5 2026, 07:20 PM
Chaznaster So I finally got around to dropping the engine in ... Mar 30 2026, 05:30 PM
Montreal914 Not familiar with the tangerine plate but the cros... Mar 30 2026, 06:25 PM
Chaznaster The transmission is off the engine. That was easie... Apr 6 2026, 06:22 PM
Montreal914 :) :smash: :driving:
Apr 6 2026, 08:39 PM
Chaznaster
Thanks. I had be... Apr 7 2026, 05:25 PM
rudedude Need a good 8mm triple square to remove the bolts.... Apr 7 2026, 07:44 AM
Montreal914 Unfortunately I do not. Numbers gets superceded. ... Apr 7 2026, 11:27 PM
Chaznaster I pulled the stack today. The 3 dog teeth and slid... Apr 14 2026, 05:15 PM
Chaznaster I got to some disassembly today and have questions... Apr 18 2026, 02:35 PM
Jack Standz To answer your question:
"For 2 and 3 gear ... Apr 18 2026, 03:20 PM
Chaznaster I got the rest disassembled this morning.
Synchr... Apr 19 2026, 07:57 AM
ctc911ctc Dog Teeth's job is to avoid lock-ups but can b... Apr 19 2026, 08:03 PM
Chaznaster Excellent news to report!
I finished the reb... May 25 2026, 05:15 PM
BillC
I finished the re... May 26 2026, 12:00 PM
Dr Evil
I finished the re... Jun 3 2026, 08:21 AM
Jack Standz :driving: May 26 2026, 12:40 AM
craig downs I've read never downshift into 1st May 29 2026, 08:28 PM
Dr Evil
You are c... Jun 3 2026, 08:20 AM
mgphoto
You are ... Jun 4 2026, 09:14 AM
dtmehall i've done it for 53 years! (carefully) May 29 2026, 08:31 PM
Chaznaster I certainly do not downshift to first at high spee... May 30 2026, 09:34 AM
Chaznaster Thanks for the tip.
I had always gone into first ... Jun 7 2026, 06:31 PM![]() ![]() |
Lo-Fi Version | Time is now: 22nd November 2026 - 03:17 PM |
