| alungershausen |
Jan 19 2026, 09:59 PM
Newbie ![]() Group: Members Posts: 15 Joined: 18-October 25 Member No.: 29,037 Region Association: Pacific Northwest |
Hi, first post ever. A friend at C&C told me to reach out. Heard this forum will help.
I bought a 1974 1.8 914 in March of 2025. It is now totally disassembled, and I am struggling with getting the engine taken apart. I cannot remove the cylinder heads, the flywheel does not turn, and the pistons do not move at all. In the last two months I tried, PB Blaster in the cylinders, also filled the case with it. I also filled the case with transmission oil and Marvel Mystery oil. Leaving it sitting for weeks on end, turning it every couple of days. I warmed up the engine with a heat gun, gently tapped the cylinder heads, also tapped the pistons. All with no success. It seems the cylinder heads are glued to the case, not one is moving. The former owner planned to replace the engine with a different one, but I am interested in bringing it back. When I drained the oil, I got about a quart of water (the car was in a field for 4 years) and a little bit of oil. Supposedly it ran 4 years ago. I am planning to attach a lever to the flywheel next, but I don't want to damage the crankshaft. I have not tried a torch yet, not sure if it will damage the case. I am also hearing different places, either the bottom of the cylinders or the case to be warmed up with the torch. The cylinder head insides are pretty rusted and will need to be replaced anyway, but I am hoping that the crank case is still ok. |
| fixer34 |
Jan 21 2026, 11:59 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,478 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest
I tend to agree with just destroying the pistons so you can get the barrels off and then split the case to see there is anything to salvage.
If you still want to try to free things up, keep in mind that pounding on a piston to try moving it inward also means the crank is trying to pull the opposite piston inward. Since there is not much leverage and no 'shock' it probably isn't going to move. You need to heat/hammer both opposite barrels. The other 2 will be trying to push outward, so the barrels should separate from the case pretty easily. |
alungershausen Seized engine Jan 19 2026, 09:59 PM
sixnotfour Type4sale Jan 19 2026, 10:05 PM
Spoke :wttc:
The heads should come off ok. Just make s... Jan 20 2026, 07:02 AM
alungershausen
:wttc:
The heads should come off ok. Just make ... Jan 20 2026, 02:45 PM
Nogoodwithusernames For hitting the pistons shape a piece of 2x4 or 4x... Jan 20 2026, 03:16 PM
914werke Is this a Rochester car? Jan 20 2026, 12:18 PM
alungershausen
As far as I know it wa... Jan 20 2026, 02:41 PM
930cabman :wttc:
These engines often get "stored... Jan 20 2026, 12:31 PM
914werke Depending on where in the PNW you are I can help ... Jan 20 2026, 12:39 PM
Nogoodwithusernames Do you have all (8x) nuts off the studs? 8x per si... Jan 20 2026, 12:58 PM
alungershausen
Do you have all (8x) nuts off the studs? 8x per s... Jan 20 2026, 02:35 PM
alungershausen
Do you have all (8x) nuts off the studs? 8x per s... Jan 20 2026, 02:39 PM
trojanhorsepower Welcome. I recently got cylinders on a 1.7 loose ... Jan 20 2026, 02:24 PM
alungershausen
Welcome. I recently got cylinders on a 1.7 loose... Jan 20 2026, 02:37 PM
alungershausen
Hi, first post ever. A friend at C&C told me ... Jan 20 2026, 03:03 PM
Aayala
Hi, first post ever. A friend at C&C told me... Jan 20 2026, 03:11 PM
alungershausen
[quote name='alungershausen' post='3241663' date=... Jan 20 2026, 03:39 PM
rick 918-S I would just break the pistons and not worry about... Jan 21 2026, 07:09 AM
Aayala
I would just break the pistons and not worry abou... Jan 21 2026, 01:24 PM
rick 918-S
I would just break the pistons and not worry abo... Jan 21 2026, 05:51 PM
rgalla9146
[quote name='Aayala' post='3241778' date='Jan 21 ... Jan 22 2026, 08:33 AM
friethmiller
I agree.
But keep in mind that you ... Jan 22 2026, 09:26 AM
Aayala
[quote name='rgalla9146' post='3241844' date='Jan... Jan 22 2026, 12:51 PM
brant chances are that pistons and cylinders are scrap d... Jan 21 2026, 01:01 PM
porschetub In this case heat is essential to freeing up the s... Jan 21 2026, 03:05 PM![]() ![]() |
Lo-Fi Version | Time is now: 24th October 2026 - 08:58 PM |
