> Seized engine, Cannot remove barrels from crank case
alungershausen
post Jan 19 2026, 09:59 PM
Hi, first post ever. A friend at C&C told me to reach out. Heard this forum will help.
I bought a 1974 1.8 914 in March of 2025. It is now totally disassembled, and I am struggling with getting the engine taken apart. I cannot remove the cylinder heads, the flywheel does not turn, and the pistons do not move at all. In the last two months I tried, PB Blaster in the cylinders, also filled the case with it. I also filled the case with transmission oil and Marvel Mystery oil. Leaving it sitting for weeks on end, turning it every couple of days. I warmed up the engine with a heat gun, gently tapped the cylinder heads, also tapped the pistons. All with no success. It seems the cylinder heads are glued to the case, not one is moving. The former owner planned to replace the engine with a different one, but I am interested in bringing it back. When I drained the oil, I got about a quart of water (the car was in a field for 4 years) and a little bit of oil. Supposedly it ran 4 years ago.
I am planning to attach a lever to the flywheel next, but I don't want to damage the crankshaft. I have not tried a torch yet, not sure if it will damage the case. I am also hearing different places, either the bottom of the cylinders or the case to be warmed up with the torch. The cylinder head insides are pretty rusted and will need to be replaced anyway, but I am hoping that the crank case is still ok.
rick 918-S
post Jan 21 2026, 07:09 AM
Hey nice rack! -Celette
I would just break the pistons and not worry about damaging the cylinders. There is no way you are reusing them anyway. Banging on the tops are banging the rods on the crank. Piston/cylinders are available new and the prices are no terrible.
Aayala
post Jan 21 2026, 01:24 PM
QUOTE(rick 918-S @ Jan 21 2026, 07:09 AM) *
For my information only... haha How exactly do you break the pistons if the case is assembled? Just was trying to visualize and got curious, not sure how that is possible.
alungershausen   Seized engine   Jan 19 2026, 09:59 PM
sixnotfour   Type4sale   Jan 19 2026, 10:05 PM
Spoke   :wttc: The heads should come off ok. Just make s...   Jan 20 2026, 07:02 AM
alungershausen   :wttc: The heads should come off ok. Just make ...   Jan 20 2026, 02:45 PM
Nogoodwithusernames   For hitting the pistons shape a piece of 2x4 or 4x...   Jan 20 2026, 03:16 PM
914werke   Is this a Rochester car?   Jan 20 2026, 12:18 PM
alungershausen   Is this a Rochester car? As far as I know it wa...   Jan 20 2026, 02:41 PM
930cabman   :wttc: These engines often get "stored...   Jan 20 2026, 12:31 PM
914werke   Depending on where in the PNW you are I can help ...   Jan 20 2026, 12:39 PM
Nogoodwithusernames   Do you have all (8x) nuts off the studs? 8x per si...   Jan 20 2026, 12:58 PM
alungershausen   Do you have all (8x) nuts off the studs? 8x per s...   Jan 20 2026, 02:35 PM
alungershausen   Do you have all (8x) nuts off the studs? 8x per s...   Jan 20 2026, 02:39 PM
trojanhorsepower   Welcome. I recently got cylinders on a 1.7 loose ...   Jan 20 2026, 02:24 PM
alungershausen   Welcome. I recently got cylinders on a 1.7 loose...   Jan 20 2026, 02:37 PM
alungershausen   Hi, first post ever. A friend at C&C told me ...   Jan 20 2026, 03:03 PM
Aayala   Hi, first post ever. A friend at C&C told me...   Jan 20 2026, 03:11 PM
alungershausen   [quote name='alungershausen' post='3241663' date=...   Jan 20 2026, 03:39 PM
rick 918-S   I would just break the pistons and not worry about...   Jan 21 2026, 07:09 AM
Aayala   I would just break the pistons and not worry abou...   Jan 21 2026, 01:24 PM
rick 918-S   I would just break the pistons and not worry abo...   Jan 21 2026, 05:51 PM
rgalla9146   [quote name='Aayala' post='3241778' date='Jan 21 ...   Jan 22 2026, 08:33 AM
friethmiller   I agree. But keep in mind that you ...   Jan 22 2026, 09:26 AM
Aayala   [quote name='rgalla9146' post='3241844' date='Jan...   Jan 22 2026, 12:51 PM
fixer34   I tend to agree with just destroying the pistons s...   Jan 21 2026, 11:59 AM
brant   chances are that pistons and cylinders are scrap d...   Jan 21 2026, 01:01 PM
porschetub   In this case heat is essential to freeing up the s...   Jan 21 2026, 03:05 PM
- Lo-Fi Version Time is now: 24th October 2026 - 08:59 PM
