> Synchro Replacement, 1st Gear
Chaznaster
post Jan 20 2026, 06:31 PM
Hi.
I am planning to address the grinding I get when going into 1st gear at anything faster than a full stop. The Pelican article on the replacing first gear seems pretty good, and I plan to search these pages for nuggets of wisdom before starting.
This thing has been grinding as long as I have had it and certainly long before that ... so I figure it is in pretty bad shape.
Pelican suggests the following parts: slider, shift fork, synchro ring and brake band, dog teeth, and maybe first gear if it is worn. I plan to open it up before getting parts - and I assume they are all available without much trouble.
I'd appreciate your thoughts on tackling this project as well as any advice.
Thanks. Christian
dr914@autoatlanta.com
post Jan 21 2026, 03:47 PM
easily done with the transmission in the car, just remove the muffler and the rear cover. We have sold many many first gear repair kits over the years and the kit comes with instructions, easily done in less than two hours
QUOTE(Chaznaster @ Jan 20 2026, 05:31 PM) *
Hi.
Thanks. Christian
Chaznaster   Synchro Replacement   Jan 20 2026, 06:31 PM
mgphoto   Hi. I am planning to address the grinding I get...   Jan 20 2026, 07:09 PM
Dave_Darling   You do know there isn’t any syncro from 2nd to ...   Jan 21 2026, 02:22 AM
brant   You do know there isn’t any syncro from 2nd to...   Jan 21 2026, 08:06 AM
ctc911ctc   You do know there isn’t any syncro from 2nd to...   Jan 21 2026, 12:39 PM
rfinegan   Dr Evil may have some of the parts both new or us...   Jan 20 2026, 07:38 PM
mepstein   My experience, after rebuilding a couple dozen tra...   Jan 20 2026, 07:39 PM
914werke   Hi. I am planning to address the grinding I get w...   Jan 21 2026, 10:05 AM
Ninja   Dr Evil may have some of the parts both new or u...   Jan 21 2026, 10:05 AM
mgphoto   Has anyone on this board ever down shifted from 30...   Jan 21 2026, 12:39 PM
ctc911ctc   The difference in gear-spin is pretty severe at th...   Jan 21 2026, 12:53 PM
brant   Has anyone on this board ever down shifted from 3...   Jan 21 2026, 12:56 PM
Dave_Darling   Has anyone on this board ever down shifted from 3...   Jan 23 2026, 02:49 AM
mgphoto   Please observe parts 41, 8 and 9. Syncro only on o...   Jan 21 2026, 12:46 PM
ctc911ctc   You may find this helpful: http://www.914world.co...   Jan 21 2026, 12:50 PM
Jack Standz   Please observe parts 41, 8 and 9. Syncro only on ...   Jan 21 2026, 03:06 PM
ctc911ctc   43 is $$$$$ Dr. Evil sol...   Jan 21 2026, 03:18 PM
dr914@autoatlanta.com   easily done with the transmission in the car, just...   Jan 21 2026, 03:47 PM
Jack Standz   43 is $$$$$ Dr. Evil so...   Jan 21 2026, 04:15 PM
Chaznaster   I've been away from this forum for some time (...   Jan 21 2026, 06:30 PM
worn   I am going to try to it with the trans in the car...   Jan 21 2026, 07:12 PM
targa72e   I have read in some other post about getting 1st g...   Jan 21 2026, 10:57 PM
rfinegan   A little sneak peak of what is involved: youtube l...   Jan 22 2026, 08:38 AM
Chaznaster   A little sneak peak of what is involved: youtube ...   Jan 22 2026, 07:32 PM
Chaznaster   I finally found some time to tear into the transmi...   Feb 15 2026, 02:43 PM
mepstein   If first gear is gone, second is usually close beh...   Feb 15 2026, 03:09 PM
ctc911ctc   If first gear is gone, second is usually close be...   Feb 16 2026, 03:31 PM
mlindner   I do have the tools needed for a small rental fee....   Feb 15 2026, 03:43 PM
jim_hoyland   :) Nice pics, thanks for posting   Feb 15 2026, 04:03 PM
914werke   Sucker is toast   Feb 16 2026, 12:25 PM
rudedude   If you haven't spend some time on the bird sit...   Feb 16 2026, 02:40 PM
Chaznaster   Thanks to all for the confirmation and advice. I ...   Feb 16 2026, 05:40 PM
ctc911ctc   Sent you a pm Thanks to all for the confirmati...   Feb 16 2026, 06:42 PM
Chaznaster   Today I separated the dog teeth and pressed in the...   Mar 1 2026, 02:21 PM
Ninja   You might have gotten lucky! :ninja: Finding ...   Mar 1 2026, 03:51 PM
brant   Zzz you’re half way there and you have the video...   Mar 1 2026, 04:12 PM
Chaznaster   I am going to go for it. Will report back!   Mar 5 2026, 07:20 PM
Chaznaster   So I finally got around to dropping the engine in ...   Mar 30 2026, 05:30 PM
Montreal914   Not familiar with the tangerine plate but the cros...   Mar 30 2026, 06:25 PM
Chaznaster   The transmission is off the engine. That was easie...   Apr 6 2026, 06:22 PM
Montreal914   :) :smash: :driving:   Apr 6 2026, 08:39 PM
Chaznaster   :) :smash: :driving: Thanks. I had be...   Apr 7 2026, 05:25 PM
rudedude   Need a good 8mm triple square to remove the bolts....   Apr 7 2026, 07:44 AM
Montreal914   Unfortunately I do not. Numbers gets superceded. ...   Apr 7 2026, 11:27 PM
Chaznaster   I pulled the stack today. The 3 dog teeth and slid...   Apr 14 2026, 05:15 PM
Chaznaster   I got to some disassembly today and have questions...   Apr 18 2026, 02:35 PM
Jack Standz   To answer your question: "For 2 and 3 gear ...   Apr 18 2026, 03:20 PM
Chaznaster   I got the rest disassembled this morning. Synchr...   Apr 19 2026, 07:57 AM
ctc911ctc   Dog Teeth's job is to avoid lock-ups but can b...   Apr 19 2026, 08:03 PM
Chaznaster   Excellent news to report! I finished the reb...   May 25 2026, 05:15 PM
BillC   Excellent news to report! I finished the re...   May 26 2026, 12:00 PM
Dr Evil   Excellent news to report! I finished the re...   Jun 3 2026, 08:21 AM
Jack Standz   :driving:   May 26 2026, 12:40 AM
craig downs   I've read never downshift into 1st   May 29 2026, 08:28 PM
Dr Evil   I've read never downshift into 1st You are c...   Jun 3 2026, 08:20 AM
mgphoto   I've read never downshift into 1st You are ...   Jun 4 2026, 09:14 AM
dtmehall   i've done it for 53 years! (carefully)   May 29 2026, 08:31 PM
Chaznaster   I certainly do not downshift to first at high spee...   May 30 2026, 09:34 AM
Chaznaster   Thanks for the tip. I had always gone into first ...   Jun 7 2026, 06:31 PM
- Lo-Fi Version Time is now: 22nd November 2026 - 03:17 PM
