> '75 Silver Metallic Mix & Match, Using what I got
neyen14
post Oct 14 2025, 06:53 PM
This '75 is my second 914, the first was a '72 that was great while it lasted. I bought both rust free cars in New Mexico and was fortunate enough to gather several loads of parts over the years. This '75 is a general conglomeration of things like put together on a 914.
I found an ad on Craigslist posted by an American Muscle Car guy who was threatening to scrap the 1.8L 914 after running the ad several times with no takers. I got it for $500 plus it came with fender flares that were never installed.
neyen14
post Jan 21 2026, 06:14 PM
Today I started the engine (in the car) for the first time. It pretty much started right up with out catching fire, external leaks, or anything breaking! After 5 - 10 minutes I noticed oil coming out of the tailpipe. The previous mentioned issues were my biggest fears so I'm not pissed.
* 1.8L heads
* 96mm cylinders w/ Deves 96mm (2mm top, 2mm mid, 5mm oil piston rings)
* Tangerine engine oil pressure relief
* stock oil cooler
* high volume oil pump
96mm (AA cylinders and pistons) BUT I swapped the AA pistons for ones that seemed to provide better oiling and would have more stability in the cylinder... and brand new rings - Deves 96mm (2mm top, 2mm mid, 5mm oil piston rings)
Looks like the #2 is the only one not getting oil in it...
I checked the oil (break in oil)level after that 5-10 minutes of running and half of the engine oil was gone!!!... some could've been "gone" cause the filter got filled but still a ton of oil missing.
I'm preparing to drop the engine and take the heads off and recheck pistons, rings, etc.... BUT I'm hoping for some miracle info someone might have for something I may have missed.... but three out of four cylinders.... can we call it "leaking"!?!?
Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image
neyen14   '75 Silver Metallic Mix & Match   Oct 14 2025, 06:53 PM
neyen14   I was told that if I got one, I would get two   Oct 14 2025, 07:23 PM
neyen14   911 front suspension and rears drilled to 911 bolt...   Oct 14 2025, 07:37 PM
mark04usa   Wow...great score. Looks like both may be buildabl...   Oct 14 2025, 08:40 PM
neyen14   Wow...great score. Looks like both may be buildab...   Oct 15 2025, 04:28 AM
Geezer914   Nice score!   Oct 15 2025, 05:27 AM
neyen14   There was a bit of time between the pics in the la...   Oct 15 2025, 03:15 PM
neyen14   Does the conduit that the clutch cable goes throug...   Nov 26 2025, 11:48 AM
barefoot   Does the conduit that the clutch cable goes throu...   Dec 6 2025, 09:30 AM
neyen14   [quote name='neyen14' post='3234342' date='Nov 26...   Dec 6 2025, 10:33 AM
fiacra   Those more knowledgeable than me will hopefully ch...   Nov 26 2025, 03:03 PM
neyen14   Hi everyone. I have these two sets of crossmember ...   Dec 4 2025, 06:46 PM
bkrantz   Looks like the reinforcement eliminates the little...   Dec 4 2025, 08:02 PM
neyen14   Looks like the reinforcement eliminates the littl...   Dec 5 2025, 06:21 AM
Root_Werks   What a great score! Both look solid from the ...   Dec 5 2025, 11:57 AM
neyen14   What a great score! Both look solid from the...   Dec 5 2025, 04:15 PM
Jack Standz   Quote from above: "Hi everyone. I have these...   Dec 6 2025, 12:21 PM
neyen14   Quote from above: "Hi everyone. I have thes...   Dec 7 2025, 08:01 AM
jim_hoyland   Great work :) Thanks for sharing…   Dec 7 2025, 09:27 PM
neyen14   Today I started the engine (in the car) for the fi...   Jan 21 2026, 06:14 PM
neyen14   I'm currently using the taller piston on the r...   Jan 21 2026, 07:55 PM
porschetub   Those taller pistons look like old NPR or AA perfo...   Jan 22 2026, 11:53 PM
neyen14   Those taller pistons look like old NPR or AA perf...   Feb 4 2026, 12:03 PM
porschetub   Those taller pistons look like old NPR or AA per...   Feb 7 2026, 04:18 PM
- Lo-Fi Version Time is now: 12th March 2026 - 03:54 AM
