> Drilling weep holes, Keeping the trunk rust free (ish).
Shivers
post Jan 22 2026, 09:55 AM
When I got my 1972 it came with trunk rust, it was 10 years old. My 1974 has a big hole where the trunk should be. But Howard here has a trunk without any holes not designed to be there. I can remember some members here, I think Sir Andy was one talking about drilling or had drilled weep holes to let the moisture out. I’m looking for some direction on location of the holes and what size has worked best. Did you weld tubing to the hole to run it past the heat shield and muffler? Thanks
Spoke
post Jan 22 2026, 11:48 AM
Jerry
I had a leak around the rear light housings so I drilled a hole on each side and put these in to drain. I've since fixed the hole but in reality the trunk should have a way to drain water.
Drain Tube
Part#: 911-631-259-02-M260
$4.50
- Lo-Fi Version Time is now: 13th March 2026 - 06:39 AM
