| EJP914 |
Jan 26 2026, 08:00 AM
Member ![]() ![]() Group: Members Posts: 282 Joined: 14-June 03 From: Monroeville, PA Member No.: 821 |
Putting A arms back on after installing new bushings.
I think ??? the right way to do the final tighten up to spec is to have the full weight of the car on the suspension. Would it be sufficient to put a jack under the A Arm and jack it up a bit to simulate the car being on the ground (load up the suspension) and then final tighten up? Also, where can I find torque specs for the 3 bolts and 1 Allen type screw that hold the A Arm to the car body? Google gives a bunch of sites with varying numbers. Thanks for the help. ED |
| Spoke |
Jan 26 2026, 10:25 AM
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,321 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None
Not sure what you mean by final tighten up. All bolts should be secure before putting any stress on the A-arm. The only adjustment should be the ride height but that should be done after a quick trip around the block to settle the suspension. All tires should be at a prescribed pressure and measure the height of the fender on both sides and note the rake of the car from front to rear. Lift the car and adjust the height screw as needed. Retest.
For the most part you will need a front end alignment because raising or lowering the front end will change the toe setting. |
EJP914 A arm installation Jan 26 2026, 08:00 AM
DennisV
Putting A arms back on after installing new bushi... Jan 26 2026, 08:35 AM
fiacra
Not sure what you mean by final tighten up. All b... Jan 26 2026, 11:47 AM![]() ![]() |
Lo-Fi Version | Time is now: 26th January 2026 - 02:08 PM |
