> Spring rate advice
BlueRidge914
post Sep 17 2024, 06:25 AM
I’d be grateful for some spring rate advice for my vintage race 914.
It’s a narrow body 2L six, 205/50 tires all around. Front torsion bars with adjustable sway bar. Rear is Bilstein Sports with adjustable spring perches, and a fixed sway bar.
My personal preference leans to a relatively softer spring all around.
Any recommendations for both torsion bar size and rear spring rate?
Thanks!
Gavin
VARAC #58
Thorshammer
post Jan 29 2026, 08:29 PM
There’s a bit more to consider when choosing spring rates.
What bushings/bearings
Are the rear trailing arms reinforced properly (and that’s not by wrapping them in 10+ lbs of perforated steel)
The anti roll bars: what are they riding in, and how well do they rotate and is their geometry reasonable
Are the shocks standard off the shelf… remember, if the rebound isn’t matched to the spring rate, there can be a some negative heave effect. So, in some cases, if you can’t control the heave, due to an insignificant damper, choosing a spring rate that matches the damper, will yield better performance overall
However:
21/225 or 21/250 works nicely IMO
BlueRidge914
post Jan 31 2026, 01:37 PM
QUOTE(Thorshammer @ Jan 29 2026, 09:29 PM) *
However:
Thanks for this.
So to answer your questions:
Rear trailing arms were reinforced around 30yrs ago the add sheet metal way. Is the other way you refer to the method Tangerine uses ie cut open and reinforced internally?
ARB in front is the Elephant hollow adjustable with teflon bushings. Rear is a stock OEM bar. All set up at least 20years ago.
Shocks front and rear are Bilstein Sports. Fronts were custom valved by Rebel, also many years ago. Spindles raised 19mm with Rebel bump steer kit. Small steering rack lift.
Solid monoballs front and rear. Front is Rebel adjustable.
21mm solid front torsion bar with Rebel solid bushings.
Rear springs are 275lb 2 1/4” adjustable perch, helper springs, thrust bearings.
I’ve raced this car 25 years with basically the same setup. So I don’t know what I may be missing!
I have contemplated the Rebel 935 style kit, but don’t know if that’s worth it (for me - a true vintage, vintage racer)
Any thoughts about what I might change/upgrade?
Much appreciated.
Gavin
slivel
post Jan 31 2026, 02:17 PM
Old car....... older driver
Much appreciated.
Gavin
[/quote]
If you make a significant change, be prepared to spend some time in development mode. If the car feels balanced and predictable, why change? You say that your vintage racing organization limits your tire so that is a major constraint. If your tire data shows even wear and temps across the tread, I would say you have optimized your setup. If your organization allows for changing suspension pickup points, you probably could achieve better performance but at the cost of being in development mode. For racing I observed a big improvement when I went to the Elephant poly bronze bushings on the rear. Soft bushings deform under side load during cornering and give unwanted changes in toe. It wasn't clear if you had done the rear of your car with high performance bushings. My shocks are also Bilstein's and were custom valved by Bilstein. I worked with one of their shock engineers and they rebuilt all four corners for me. Unfortunately they don't provide this service any longer.
BlueRidge914
post Jan 31 2026, 04:49 PM
[quote name='slivel' date='Jan 31 2026, 03:17 PM' post='3243045']
Much appreciated.
Gavin
[/quote]
[/quote]
Your point that if it works well, why change is right on - and far too sensible! Our prep rules have changed from a 1972 cut off to build to what was available up to 1979.
Regarding rear suspension: I also have Tangerine solid trailing arm brackets, and Rebel hollow pivot shafts for bushings.
I need treaded tires, and currently run Nittos. The new Hoosiers sound fantastic, but at twice the price I can’t justify it. Maybe someday.
Thanks for the input.
Gavin
BlueRidge914   Spring rate advice   Sep 17 2024, 06:25 AM
brant   What diameter front torsion springs do you have? ...   Sep 17 2024, 01:32 PM
BlueRidge914   It was more than twenty years ago since I installe...   Sep 17 2024, 07:15 PM
slivel   I believe that you get performance gains by going ...   Sep 18 2024, 02:26 PM
campbellcj   I believe that you get performance gains by going...   Sep 23 2024, 01:47 PM
yeahmag   What type of racing? What tires? Do you have an LS...   Sep 20 2024, 03:31 PM
BlueRidge914   Tires are 205/50x15 all around, treaded - no slick...   Sep 23 2024, 05:02 AM
BlueRidge914   That is great advice - thanks. And sort of what I ...   Sep 23 2024, 03:48 PM
yeahmag   I think what Chris says is a good place to start. ...   Oct 2 2024, 04:47 PM
Thorshammer   There’s a bit more to consider when choosing spr...   Jan 29 2026, 08:29 PM
BlueRidge914   There’s a bit more to consider when choosing sp...   Jan 31 2026, 01:37 PM
slivel   So to answer your questions: Rear trailing arms we...   Jan 31 2026, 02:17 PM
BlueRidge914   So to answer your questions: Rear trailing arms w...   Jan 31 2026, 04:49 PM
Thorshammer   Ok, The next step is a leap in faith, also in mo...   Feb 2 2026, 08:37 PM
brant   Ok, The next step is a leap in faith, also in m...   Feb 3 2026, 08:34 AM
yeahmag   I ran the rear roller bearings and greatly prefer ...   Feb 3 2026, 03:35 PM
BlueRidge914   Much to consider - thanks. Answering above: stock...   Feb 5 2026, 01:24 PM
- Lo-Fi Version Time is now: 4th October 2026 - 11:40 PM
