| tomeric914 |
Jan 31 2026, 10:00 AM
One Lap of America in a 914! ![]() ![]() ![]() Group: Members Posts: 1,310 Joined: 25-May 08 From: Syracuse, NY Member No.: 9,101 Region Association: North East States
Yes, I know this is a bad idea, let's get that out of the way.
Looking for a place to mount the clutch reservoir and the seam on the gas tank sure would make a good mounting spot. It appears that the seam weld is closer to the tank itself, but that position could vary depending on how good or bad of a day the operator was having. Two options using the seam: 1. Drill the seam as far away from the tank as possible using the smallest reasonable fastener diameter that would reliably hold the reservoir in place and survive vibrations, bumps, etc. Literally a 5 minute job. Potential for a fuel leak down the road if I mess up. 2. Design a billet clamp to pinch the seam and bolt the reservoir to the clamp. Not difficult to design. Expensive to machine a one off part. Definitely would not leak. It could be located somewhere else, but this location is easy to get to and provides for a good route for the reservoir to master cylinder line. I do see the mounting tab for the evap canaster that could be used if I made a bracket for it. The line routing for that location wasn't as good. Standing seam clamps for mounting solar panels on metal roofs is another way, but those were a bit too large. I am open to suggestions! |
| bkrantz |
Jan 31 2026, 08:25 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,588 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains
How about a bracket that attaches to the brake MC mount?
tomeric914 Gas tank seam, how close is the weld to the edge? Jan 31 2026, 10:00 AM
mlindner How about just mounting to the brace on the cowl (... Jan 31 2026, 01:00 PM
tomeric914
How about just mounting to the brace on the cowl ... Jan 31 2026, 02:03 PM
Ninja Tygaboy made a nice mount for both brake and clutc... Jan 31 2026, 02:16 PM
Rob-O As mentioned above, why not mount it on the cowl b... Jan 31 2026, 04:14 PM
tomeric914
As mentioned above, why not mount it on the cowl ... Jan 31 2026, 06:14 PM
Ninja I think that was on his LS car. I haven't gone... Jan 31 2026, 07:00 PM
tygaboy If it were me, I'd get a different reservoir t... Jan 31 2026, 07:15 PM
Ninja Here's a trick for welding on a gas tank that ... Jan 31 2026, 07:21 PM![]() ![]() |
Lo-Fi Version | Time is now: 1st February 2026 - 05:23 AM |
