| frank_c |
Feb 4 2026, 07:19 PM
Newbie ![]() Group: Members Posts: 40 Joined: 29-December 24 From: Austin, TX Member No.: 28,542 Region Association: None |
Hello,
I started replacing the Pushrod Tubes yesterday, and I noticed that the top of the stem of #4 intake valve has a divot worn in it from the rocker (#4 valve stem & rocker adj screw photos below). The other three valves on this bank are fine, and I haven't pulled the rockers on the other bank yet. I purchased the car about a year ago, and here is some engine related info based on an engine build sheet, the receipts that came with the car, and what I can see:
I do not see valve springs listed on the build sheet, so I am assuming that the single spring currently installed is the OEM spring, and not an HD spring. So, I have two goals here:
For the short-term goal, if I leave things as-is this will obviously make setting the valve lash on that valve challenging. So I would like to hear folks' opinions on the use of a Valve Cap on that one valve (and any others with similar issue I may find). If I install a cap, should I replace the rocker adjustment screw for that valve as well? Or is there any other short-term option that does not involve pulling the head? Or just run it as-is knowing that #4 intake may not be getting full lift, and tear into it after the event? Example valve caps: https://www.cbperformance.com/product-p/1522.htm I also have some questions regarding the long-term fix, but I'll leave that for another thread when that time comes. Thanks, Frank |
Ninja I'd rate that as toast...
Unless you know the... Feb 4 2026, 07:52 PM
Ninja I would not use steel pushrods in this application... Feb 4 2026, 08:09 PM![]() ![]() |
Lo-Fi Version | Time is now: 4th February 2026 - 11:43 PM |
