| TRP |
Feb 5 2026, 08:42 PM
Member ![]() ![]() Group: Members Posts: 362 Joined: 2-September 23 From: Morgan Hill, CA Member No.: 27,559 Region Association: None
Hello,
As I waiit for Ken to finish building my 2056 I want to keep moving on other projects. As I mentioned before, I am keeping the LJet, running 2.0 heads, 2.0 intake runners, the flexible couplers from 914Werke, and the larger bus throttle body. I have read a few threads on this conversion/ upgrade and understand it's straightforward, but I may need to verify the AFR. Should I buy a wideband gauge and sensor? Or is this as easy as "adjusting some big wheel one click"? If I should get a wideband setup, which one do you all recommend? Thanks in advance. |
| Ninja |
Feb 5 2026, 10:05 PM
Member ![]() ![]() Group: Members Posts: 211 Joined: 25-September 25 From: Granbury Texas Member No.: 29,004 Region Association: Southwest Region |
I would not do a T4 without both a wideband and a spark plug located verified accurate CHT.
The wide band SHOWS you how much to "turn that wheel" and which direction you need to go. The CHT keeps you from melting it down. There are multiple ways to "turn the wheel" on a L-jet one of which is actually adjusting the flap tension on the AFM by turning a wheel and relocking the index. I haven't bought a new one in years. I don't know what the hot ticket is today. Biggest problem on a T4 appears to be sensor placement IMO. A 4-1 exhaust like Tangerine or MSDS is the easy button but $$$. Normal HE pipe only sees one cylinder. It will still read fine for that single cylinder only. Muffler exit is NG as it sees oxygen from the atmosphere for 8-12" deep. The Bursch muffler set ups have an excellent spot directly before the muffler. |
TRP Wideband AFR gauge and sensor? Feb 5 2026, 08:42 PM
TRP Thanks Ninja, I literally have no idea where that ... Feb 5 2026, 10:18 PM
rfinegan Experts say.....Mount the CHT thermocouple under t... Feb 6 2026, 06:46 AM
Olympic 914
Experts say.....Mount the CHT thermocouple under ... May 18 2026, 04:36 PM
emerygt350
Experts say.....Mount the CHT thermocouple under... May 18 2026, 04:54 PM
rfinegan FWIW:
I am finally retiring my VDO gauge( off 50 d... Feb 6 2026, 06:55 AM
Chad911sc I installed the AEM afr in my car and it has been ... Feb 6 2026, 07:54 AM
FlacaProductions I have the Performance Electronics wideband in my ... Feb 6 2026, 09:15 AM
TRP I really like the idea of not having to add a gaug... Feb 6 2026, 09:31 AM
FlacaProductions I was thinking that I wouldn't keep the AFR in... Feb 6 2026, 10:28 AM
TRP I followed your lead and installed mine pretty muc... May 18 2026, 12:20 PM
FlacaProductions Excellent - glad it helped! May 18 2026, 02:39 PM![]() ![]() |
Lo-Fi Version | Time is now: 18th May 2026 - 06:39 PM |
