> Wideband AFR gauge and sensor?
TRP
post Feb 5 2026, 08:42 PM
Hello,
As I waiit for Ken to finish building my 2056 I want to keep moving on other projects. As I mentioned before, I am keeping the LJet, running 2.0 heads, 2.0 intake runners, the flexible couplers from 914Werke, and the larger bus throttle body. I have read a few threads on this conversion/ upgrade and understand it's straightforward, but I may need to verify the AFR.
Should I buy a wideband gauge and sensor? Or is this as easy as "adjusting some big wheel one click"?
If I should get a wideband setup, which one do you all recommend?
Thanks in advance.
rfinegan
post Feb 6 2026, 06:55 AM
FWIW:
I am finally retiring my VDO gauge( off 50 degrees HIGH the other day) and while I can do math pretty quick, I did flip out with the high reading while in the melt my head temp range.
Can anyone recommend the speed hut CHT gauge?
https://speedhut.com/gauge-applications/rev...500f-w-warning/
3 User(s) are reading this topic (2 Guests and 0 Anonymous Users)
1 Members: Chad911sc
- Lo-Fi Version Time is now: 18th May 2026 - 06:35 PM
