| sburns1967 |
Dec 3 2025, 11:27 AM
Newbie ![]() Group: Members Posts: 8 Joined: 16-May 25 From: London, Ontario, Canada Member No.: 28,775 Region Association: Canada |
I have a 1973 914/4 2.0 which is is partially disassembled.
It came with two hot air blowers: Single Port - Working Motor In 1973 there was apparently a switch between the dual outlet blower to a single outlet with a Y pipe. I was thinking I would like to use the dual outlet one so I thought I would swap in the working motor. Two questions: 1) Does the dual outlet unit provide better heat flow through the heat exchangers than the single outlet with a Y connector? Any pointers to pictures of each type mounted/hoses? 2) How to remove the motor: Removed the 6 screws on the motor flange Thanks in advance Scott Attached thumbnail(s) |
| Osnabruck914 |
Feb 7 2026, 09:12 PM
Member ![]() ![]() Group: Members Posts: 201 Joined: 19-December 22 From: United States Member No.: 27,038 Region Association: South East States |
Move to Florida. I removed my entire blower system and I still get more than enough heat for the climate here. Kept all the parts, of course.
Osnabruck914 |
sburns1967 Heater Blower Motor Dec 3 2025, 11:27 AM
chmillman
I have a 1973 914/4 2.0 which is is partially dis... Dec 3 2025, 11:41 AM
wonkipop
I have a 1973 914/4 2.0 which is is partially di... Feb 8 2026, 01:20 AM
Olympic 914 If you have good heat exchangers, there will be en... Dec 3 2025, 01:50 PM
wonkipop in terms of what the factory did with the blowers.... Dec 3 2025, 02:10 PM
dtmehall I have always found that the heat from a single ho... Dec 3 2025, 05:39 PM
sburns1967 Thanks for the info and detailed review of the two... Dec 3 2025, 09:16 PM
DRPHIL914
Thanks for the info and detailed review of the tw... Dec 5 2025, 08:33 AM
sburns1967 I have received the splitter from AA and tried it ... Feb 7 2026, 08:10 PM
chmillman
I have received the splitter from AA and tried it... Feb 8 2026, 12:34 AM
sburns1967
I have a 1973 914/4 2.0 which is is partially dis... Feb 7 2026, 08:22 PM
WFG On the early model the hose going to the passenger... Feb 7 2026, 09:06 PM
dtmehall except when the iguanas fall down from the cold
... Feb 7 2026, 09:17 PM![]() ![]() |
Lo-Fi Version | Time is now: 8th February 2026 - 03:09 AM |
