> heat exchanger questions
Cvrguy
post Feb 8 2026, 09:36 PM
The heat exchanger jackets on my exhaust are rusted and loose while the exhaust pipes seem fine. I'm thinking of just removing them with a cutoff wheel to eliminate the rattling. The heater valves are 53 years old and work about as well as you would think. Don't really need them here in SoCal. Is there a cap for the cooling fan outlets to the heat exchangers or do I need to fabricate something? If I can contain that cooling airflow, I would imagine that the engine cooling will be a bit more effective.
davep
post Feb 8 2026, 11:06 PM
914 Historian
Yes, you can eliminate the heater system in it's entirety, but you may be giving up the window defogging on cool mornings.
There are hinged flaps of the fan shroud outlet ports, but a better solution should be devised to block permanently. Also remember to cap the tubes running in the longitudinals to keep critters from entering.
- Lo-Fi Version Time is now: 10th February 2026 - 05:03 AM
