> Correct order horn connector spacers, Looking for the right order to fix the standard horn connector set
Marcel Aircooled
post Feb 13 2026, 08:31 AM
Region Association: Europe
So I bought a standard 38cm steering wheel plus horn and had to replace the spacer and screw set to fix the horn connector.
I got the set from Sportwagen Eckert in Germany (I live in The Netherlands) and not sure what the correct order is to fix the metal and plastic spacers to make my horn work in the end.
So I have this:
Starting from the horn up side down what do I need to add first before installing the base plate? And what inbetween the base plate and the connector? Finally what on top?
Is it just the order from the picture above: horn - black pieces - base plate - orange spacer and big metal spacer - connector - small spacer and screw?
Pictures would be perfect!
Thanks!
- Lo-Fi Version Time is now: 15th February 2026 - 01:04 PM
