> Questions: replacing center console panels and bits
DC_neun_vierzehn
post Feb 15 2026, 10:16 AM
The bottom panel of my center console has always bothered me. The wood core is deteriorating and upon closer inspection I can see that it's been repaired and recovered already. So I cut a new piece of wood for the core. I plan to use vinyl I saved from an old back pad as it appears to be a good match.
Here are my current questions:
1. What glue is recommended for vinyl to wood on center console pieces?
2. I'm going to replace the worn black leather shift boot with 914 Rubber's leather replacement boot. The plastic ring at the base of the factory leather shift boot is cracked and broken in several places. I don't think I'm going to be able to reuse it (trying to remove the staples will probably cause further damage). Any suggestions on a replacement ring?
FlacaProductions
post Feb 15 2026, 03:40 PM
Just to be clear - it's DAP Weldwood contact cement - red and black can.
You may want to go this way - or maybe someone who can measure and 3D print the part - that would be great.
I'm a bit unclear as to what that little collar actually does - i wonder if you could just make the relief cuts in the leather and glue it to the underside of the flat base and be good. I got lucky in that my collar was intact.
https://www.ebay.com/itm/325703412043?chn=p...NUaNkh800NV1Mr8
2 User(s) are reading this topic (1 Guests and 0 Anonymous Users)
1 Members: Ninja
- Lo-Fi Version Time is now: 15th February 2026 - 09:15 PM
