| DC_neun_vierzehn |
Feb 15 2026, 10:16 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 624 Joined: 16-November 20 From: Coastal Delaware Member No.: 24,893 Region Association: MidAtlantic Region
The bottom panel of my center console has always bothered me. The wood core is deteriorating and upon closer inspection I can see that it's been repaired and recovered already. So I cut a new piece of wood for the core. I plan to use vinyl I saved from an old back pad as it appears to be a good match.
Here are my current questions: 1. What glue is recommended for vinyl to wood on center console pieces? 2. I'm going to replace the worn black leather shift boot with 914 Rubber's leather replacement boot. The plastic ring at the base of the factory leather shift boot is cracked and broken in several places. I don't think I'm going to be able to reuse it (trying to remove the staples will probably cause further damage). Any suggestions on a replacement ring? |
| bkrantz |
Feb 15 2026, 08:04 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,600 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains
A couple of suggestions:
Round all the edges on the new plywood piece, so the new vinyl has less chance of tearing. The stock panel has a thin pad. You can duplicate that or not. Think about the total length and width of you new piece plus the vinyl (and maybe pad). If too wide it will be a challenge to install and will tend to spread the side panels. |
DC_neun_vierzehn Questions: replacing center console panels and bits Feb 15 2026, 10:16 AM
FlacaProductions woodweld contact cement for sure.
As to the boot r... Feb 15 2026, 10:26 AM
mepstein Wildwood contact cement. Just make sure to use two... Feb 15 2026, 10:49 AM
DC_neun_vierzehn I wonder if I could take a rubber shift boot from ... Feb 15 2026, 03:05 PM
FlacaProductions Just to be clear - it's DAP Weldwood contact c... Feb 15 2026, 03:40 PM![]() ![]() |
Lo-Fi Version | Time is now: 15th February 2026 - 10:30 PM |
