| ctc911ctc |
Oct 9 2025, 07:43 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,389 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States
1970 - 914-6 All stock
Got the car off the rack after a 1 year clean up documented here: http://www.914world.com/bbs2/index.php?sho...3371&st=100 - tightened the lugs, check one more time for leaks....... Car started first try, backed out of the driveway and went around the block Drive strong.....very strong...... #2 cyl-carb is still 'spitting' definitely not backfiring. Chasing this through my trusty guide: https://www.performanceoriented.com/special-procedures-1 See "notes" section Seems that when I performed the Lean Best Idle procedure #2 failed during the procedure......the diagnosis within the document states that either the path in that carb #2 is blocked or the jet is the wrong size - my bet is a clog......though the carbs were very clean when I got the car. There is a little noise from the right side, that in a 914-2L 4Cyl would be considered quiet, my hope is that it is not valve noise and may be exhaust leaking......did I tighten the heater manifold small nuts????? dry.gif Carb advice sought from those that have chased a SPITTING Carb |
| Superhawk996 |
Feb 15 2026, 02:54 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,144 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
Fuel pressure isn’t going to be the problem leading to richness.
Need to know the answers to Porschetub’s questions especially Venturi size. |
| ctc911ctc |
Feb 15 2026, 02:59 PM
Superhawk - as always you come through.
Soo, I should take an accounting of all of the parts that have to do with fuel regulation and carb setup - jets, venturis, etc? Fuel pressure isn’t going to be the problem leading to richness. Need to know the answers to Porschetub’s questions especially Venturi size. |
| 930cabman |
Feb 16 2026, 05:57 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,865 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
Superhawk - as always you come through. Soo, I should take an accounting of all of the parts that have to do with fuel regulation and carb setup - jets, venturis, etc? Fuel pressure isn’t going to be the problem leading to richness. Need to know the answers to Porschetub’s questions especially Venturi size. Accounting 100%, include the whole schebang from the pump to every part in the carbs. Black plugs are too rich, unless they have been idling for a long period of time. Might consider going one level hotter plug if everything appears in order |
ctc911ctc SPITTING CARB - 914-6 all stock Oct 9 2025, 07:43 AM
Superhawk996 Unclear on the question here?
You need to resolv... Oct 9 2025, 08:41 AM
ctc911ctc Thank you for the reply SH,
I was more or less lo... Oct 9 2025, 09:34 AM
slivel
I was more or less l... Oct 9 2025, 10:07 AM
Superhawk996 Anytime carbs are apart it’s good standard pract... Oct 9 2025, 09:57 AM
infraredcalvin
Goes without saying - make sure valves are adjust... Oct 9 2025, 11:15 AM
ctc911ctc This is the exact guidance I was looking for, than... Oct 9 2025, 10:42 AM
ctc911ctc Less than 1 hour of run time between now and this ... Oct 9 2025, 11:19 AM
Superhawk996
Less than 1 hour of run time between now and this... Oct 9 2025, 11:46 AM
ctc911ctc Understood - good solid engineering exercise......... Oct 9 2025, 12:49 PM
930cabman weak/broken valve spring?
or some other issue wi... Oct 9 2025, 12:49 PM
ctc911ctc UPDATE!!!!!!!
Teener... Dec 13 2025, 02:28 PM
Cairo94507 I remember the 6's I've had that still has... Dec 13 2025, 03:41 PM
rgalla9146 I just started (6pm) my dead stock 6 after it sat... Dec 13 2025, 06:47 PM
fixer34
I just started (6pm) my dead stock 6 after it sa... Dec 14 2025, 07:58 AM
mate914
I just started (6pm) my dead stock 6 after it s... Dec 14 2025, 08:05 AM
930cabman Guess I'm lucky to have a 914/6 conversion and... Dec 14 2025, 10:16 AM
brant Measure the volume from the accelerator pump diagr... Dec 14 2025, 10:36 AM
gereed75 Agree with everything here except one thing- the h... Dec 14 2025, 11:18 AM
930cabman
Agree with everything here except one thing- the ... Dec 14 2025, 04:35 PM
ctc911ctc Thank you all teeners for the replies, here are so... Dec 14 2025, 08:24 PM
930cabman Idle passageways plugged? drill/grind away the lea... Dec 15 2025, 02:00 PM
ctc911ctc
Idle passageways plugged? drill/grind away the le... Dec 15 2025, 02:51 PM
930cabman
Idle passageways plugged? drill/grind away the l... Dec 15 2025, 02:57 PM
Ninja Not hard to flush the circuits but if the critter ... Dec 15 2025, 03:06 PM
930cabman
Not hard to flush the circuits but if the critter... Dec 16 2025, 05:53 PM
ctc911ctc Great notes Ninja, comments added within
Not h... Dec 16 2025, 07:38 PM
Ninja Just re-read thread. You're stock so the origi... Dec 15 2025, 04:02 PM
Ninja Double post gremlin got me again! Dec 15 2025, 04:02 PM
ctc911ctc Hi,
I came back to this car after a few major tri... Feb 14 2026, 11:41 AM
porschetub
Hi,
I came back to this car after a few major tr... Feb 14 2026, 11:25 PM
ctc911ctc
Are those plugs any good they look old to me ? se... Feb 15 2026, 03:01 PM
Superhawk996
here are the plugs – the 1,2,3 plugs look goo... Feb 15 2026, 12:07 AM
Ninja Clean plugs, check float levels, run again.
If al... Feb 14 2026, 02:01 PM
ctc911ctc Thank you EVERYONE for contribution - this has bee... Feb 15 2026, 02:37 PM
ctc911ctc bump - Feb 15 2026, 02:50 PM
Superhawk996 There is one plug in there that doesn’t look “... Feb 15 2026, 03:36 PM
rgalla9146 Don't trust the marking on jets.
Get a jet ... Feb 16 2026, 07:01 AM
ctc911ctc *******UPDATE*********
I was getting pretty frust... Apr 4 2026, 09:28 PM
porschetub
I was getting pretty frus... Apr 5 2026, 12:13 AM
930cabman All is well that ends well. but what could have be... Apr 5 2026, 04:40 AM
brant They need a full high end rebuild. Possibly butte... Apr 6 2026, 10:25 AM
930cabman
They need a full high end rebuild. Possibly butt... Apr 6 2026, 10:40 AM
Superhawk996
They need a full high end rebuild. Possibly butt... Apr 6 2026, 07:58 PM
brant An air leak is unmetered air and effects mixture a... Apr 6 2026, 11:18 AM
ctc911ctc ****UPDATE*****
I have another thread that talks ... Aug 27 2026, 06:05 PM
Superhawk996 :popcorn:
Video looks like you might have gone b... Aug 27 2026, 06:47 PM
ctc911ctc
:popcorn:
Video looks like you might have gone ... Aug 28 2026, 06:42 AM
Superhawk996 if i remove the play will I introduce binding or ... Aug 28 2026, 07:28 AM
rgalla9146 If you hear a clacking noise at idle and it can be... Aug 28 2026, 05:40 AM
ctc911ctc UPDATE
spent an hour
Warmed the engine - still s... Aug 28 2026, 02:24 PM
Superhawk996
I need to fix cyl 2 and 3 on the carb
:agre... Aug 28 2026, 09:11 PM
ctc911ctc On my way to buy carb cleaner now -
Question - s... Aug 29 2026, 07:03 AM
brant Spray carb cleaner on the loose idle shafts
If th... Aug 28 2026, 04:26 PM
ctc911ctc ******NEW INFORMATION********
So, where we last l... Sep 7 2026, 05:28 PM
Superhawk996 27 mm Venturis :wub: these are your best shot at ... Sep 7 2026, 05:46 PM
ctc911ctc Was hoping you would be on line!
I watched ai... Sep 7 2026, 05:58 PM
930cabman :popcorn:
carb popping is not uncommon with thes... Sep 7 2026, 06:21 PM
Superhawk996 I’d bet money the bouncing of the throttle shaft... Sep 7 2026, 06:41 PM
ctc911ctc Tail of 2 sets of carbs
I purchased a car with so... Sep 14 2026, 06:17 PM
ctc911ctc ***UPDATE***
I removed the Starboard carb and swa... Sep 15 2026, 07:57 PM
Superhawk996
neighbors are a bot fussy about 914s and this mag... Sep 15 2026, 08:06 PM
ctc911ctc AAAAaaaannnnnddd the Lemon Tree!
neighbors... Sep 16 2026, 02:26 PM
ctc911ctc OK, making progress,
I put the carbs on the car t... Sep 17 2026, 08:07 AM
brant How is the side to side air meter numbers now? Wit... Sep 17 2026, 08:25 AM
ctc911ctc I synced side to side about 5ish, runs smoother. I... Sep 17 2026, 06:24 PM
ctc911ctc ******UPDATE******
Getting better, still bucking ... Oct 4 2026, 07:19 PM
sixnotfour 3 Half Turns equals 1-1/2 Turns. Oct 4 2026, 08:41 PM
Superhawk996 I’ll go back and read all of Performance Oriente... Oct 5 2026, 12:33 AM
Superhawk996 Page 56 from Weber Tuning Manual
See the highligh... Oct 5 2026, 01:05 AM
Superhawk996 Here’s the cutaway (from IDF guide) that shows y... Oct 5 2026, 01:09 AM
Superhawk996 School of hard knocks stuff going on here but youâ... Oct 5 2026, 01:38 AM
930cabman Crazy as it sounds, I have had luck opening each a... Oct 5 2026, 07:14 AM
ctc911ctc @superhawk - thank you for the detailed reply, VER... Oct 5 2026, 08:08 AM
Superhawk996
Here is my problem - I understand the theory and... Oct 5 2026, 10:04 AM
Superhawk996 Yeah, sorry had I known what you were doing we sho... Oct 5 2026, 09:53 AM
ctc911ctc Lots of travel ahead, may be 10 days for an update Oct 5 2026, 07:16 PM
Superhawk996
Lots of travel ahead, may be 10 days for an updat... Oct 5 2026, 08:16 PM
I performed the following runs reall... Oct 22 2026, 02:26 PM
Superhawk996
I interpret this as I should in every cylinder b... Oct 22 2026, 03:20 PM
Superhawk996 What happens if you disconnect spark plug wire fro... Oct 22 2026, 03:14 PM
Superhawk996 This whole process of best lean, set idle speed, b... Oct 22 2026, 04:27 PM![]() ![]() |
Lo-Fi Version | Time is now: 22nd October 2026 - 07:48 PM |
