| nmkimosabe |
Feb 16 2026, 11:24 AM
Newbie ![]() Group: Members Posts: 24 Joined: 16-March 25 From: Santa Fe, NM Member No.: 28,660 Region Association: Rocky Mountains |
As a 914 newbie does the entire regulator need to be removed in order to remove the glass or can the forward bolt & plastic block that lifts the window be removed and the window carefully angled to remove it? I need to replace the forward channel guide fuzzy and I don't think it can be done with the window in place.
| Ishley |
Feb 16 2026, 11:59 AM
Member ![]() ![]() Group: Members Posts: 318 Joined: 4-October 21 From: Clarendon Hills Il Member No.: 25,957 Region Association: Upper MidWest
https://youtu.be/TMQt5OYOdqQ
The glass can be removed without taking the regulator out. There are two different doors… 70-72 and 73-76. The YouTube video is the later… and is an assembly video but should tell you what you need to know. I Always suggest stating the year of the car on a post as there are differences by year. |
| nmkimosabe |
Feb 16 2026, 12:02 PM
https://youtu.be/TMQt5OYOdqQ The glass can be removed without taking the regulator out. There are two different doors… 70-72 and 73-76. The YouTube video is the later… and is an assembly video but should tell you what you need to know. I Always suggest stating the year of the car on a post as there are differences by year. |
| nmkimosabe |
Feb 16 2026, 02:11 PM
I watched the video, but it looks like Ian took the regulator and the guides out first and then reinstalled everything including the glass.
nmkimosabe Door Glass Removal Feb 16 2026, 11:24 AM
nmkimosabe Thanks Ed for the suggestion and my car is a 1974 ... Feb 16 2026, 12:03 PM
Ishley Yes but the glass goes in last… so in reverse or... Feb 16 2026, 02:18 PM
nmkimosabe Understood and it's the channel insert that is... Feb 16 2026, 02:35 PM
TonyA Be careful with that front adjusting screw. If I a... Feb 16 2026, 03:08 PM
nmkimosabe I could possibly see that happening, but I think I... Feb 16 2026, 05:29 PM![]() ![]() |
Lo-Fi Version | Time is now: 16th February 2026 - 07:37 PM |
