| nmkimosabe |
Feb 16 2026, 11:24 AM
Newbie ![]() Group: Members Posts: 24 Joined: 16-March 25 From: Santa Fe, NM Member No.: 28,660 Region Association: Rocky Mountains |
As a 914 newbie does the entire regulator need to be removed in order to remove the glass or can the forward bolt & plastic block that lifts the window be removed and the window carefully angled to remove it? I need to replace the forward channel guide fuzzy and I don't think it can be done with the window in place.
| Ishley |
Feb 16 2026, 02:18 PM
Member ![]() ![]() Group: Members Posts: 318 Joined: 4-October 21 From: Clarendon Hills Il Member No.: 25,957 Region Association: Upper MidWest
Yes but the glass goes in last… so in reverse order you can take the roll up window out and then get to the guide. I assume you’re talking about the rear guide. The front guide is part of the triangle window.
nmkimosabe Door Glass Removal Feb 16 2026, 11:24 AM
Ishley https://youtu.be/TMQt5OYOdqQ
The glass can be rem... Feb 16 2026, 11:59 AM
nmkimosabe
The glass can be re... Feb 16 2026, 12:02 PM
nmkimosabe I watched the video, but it looks like Ian took th... Feb 16 2026, 02:11 PM
nmkimosabe Thanks Ed for the suggestion and my car is a 1974 ... Feb 16 2026, 12:03 PM
nmkimosabe Understood and it's the channel insert that is... Feb 16 2026, 02:35 PM
TonyA Be careful with that front adjusting screw. If I a... Feb 16 2026, 03:08 PM
nmkimosabe I could possibly see that happening, but I think I... Feb 16 2026, 05:29 PM![]() ![]() |
Lo-Fi Version | Time is now: 16th February 2026 - 07:36 PM |
