| nmkimosabe |
Feb 16 2026, 11:24 AM
Newbie ![]() Group: Members Posts: 24 Joined: 16-March 25 From: Santa Fe, NM Member No.: 28,660 Region Association: Rocky Mountains |
As a 914 newbie does the entire regulator need to be removed in order to remove the glass or can the forward bolt & plastic block that lifts the window be removed and the window carefully angled to remove it? I need to replace the forward channel guide fuzzy and I don't think it can be done with the window in place.
| TonyA |
Feb 16 2026, 03:08 PM
Nachmal ![]() ![]() ![]() Group: Members Posts: 648 Joined: 17-November 16 From: Hilltown PA Member No.: 20,596 Region Association: North East States
Be careful with that front adjusting screw. If I am not mistaken you could turn it to far and dent the door. Guys am I correct on this ?
| nmkimosabe |
Feb 16 2026, 05:29 PM
I could possibly see that happening, but I think I've found the sweet spot on mine and there's plenty of clearance. Appreciate the heads up.
nmkimosabe Door Glass Removal Feb 16 2026, 11:24 AM
Ishley https://youtu.be/TMQt5OYOdqQ
The glass can be rem... Feb 16 2026, 11:59 AM
nmkimosabe
The glass can be re... Feb 16 2026, 12:02 PM
nmkimosabe I watched the video, but it looks like Ian took th... Feb 16 2026, 02:11 PM
nmkimosabe Thanks Ed for the suggestion and my car is a 1974 ... Feb 16 2026, 12:03 PM
Ishley Yes but the glass goes in last… so in reverse or... Feb 16 2026, 02:18 PM
nmkimosabe Understood and it's the channel insert that is... Feb 16 2026, 02:35 PM![]() ![]() |
Lo-Fi Version | Time is now: 16th February 2026 - 07:39 PM |
