> 1974 2.0l w/dual 34ICTs having blowby
justjoel
post Feb 16 2026, 09:36 AM
Finally got my project 914 on the road and it's running really good with dual 34ICTs but I started noticing burning oil smells in the cabin. Now it does have a minor oil leak, I believe from the distributor o-ring and I will be addressing that but I realized it was blowing smoke/oil from the crankcase breather and the cylinder head vents. I installed a catch-can where I routed the crankcase breather and cylinder head vents to and have a filter on top of the catch can but it's still smoking out the filter and getting into the cabin where it proceeds to give me a nice migraine after 20-30 min drive.
I believe I should remove the top filter and run a line into the carbs for the vapors to be sucked back into the system, is that correct? Will that gum up my carbs?
Now the car sat for probably 20+ years prior to me picking it up and fixing it but it fires right up, no issues and runs "cool" and strong. Compression tests out good, valves have been adjusted to the best of my ability and there is no smoke out of the tailpipe. How concerned should I be about blowby? When I open the oil fill cap there is quite a bit of smoke and pressure coming out. I am unfamiliar with aircooled engines but I would think the piston rings are worn. Should I be thinking rebuild time? As in new pistons, cylinders, rings etc. If so, what "while you're in there" things should I start budgeting for?
Please let me know your thoughts.
Thank you.
914sgofast2
post Feb 16 2026, 03:19 PM
Excessive blowby on an engine that has sat for a long period of time often indicates that the oil control rings have gotten gummed up. Change the oil more frequently and drive it .
justjoel
post Feb 17 2026, 06:33 AM
QUOTE(914sgofast2 @ Feb 16 2026, 04:19 PM) *
I like your thought process. What are your thoughts on soaking the cylinders in berrymans b12 like the Toyota folks have to do? Basically putting it down the spark plug holes to free up the rings. I'm down to try anything before tearing the engine apart and rebuilding it. I think that is inevitable but I'd like to get a few months of driving out of it. Thanks for the feedback!
4 User(s) are reading this topic (3 Guests and 0 Anonymous Users)
1 Members: burton73
- Lo-Fi Version Time is now: 16th June 2026 - 11:08 AM
