| justjoel |
Feb 16 2026, 09:36 AM
Newbie ![]() Group: Members Posts: 7 Joined: 25-June 25 From: Chattanooga TN Member No.: 28,855 Region Association: None |
Finally got my project 914 on the road and it's running really good with dual 34ICTs but I started noticing burning oil smells in the cabin. Now it does have a minor oil leak, I believe from the distributor o-ring and I will be addressing that but I realized it was blowing smoke/oil from the crankcase breather and the cylinder head vents. I installed a catch-can where I routed the crankcase breather and cylinder head vents to and have a filter on top of the catch can but it's still smoking out the filter and getting into the cabin where it proceeds to give me a nice migraine after 20-30 min drive.
I believe I should remove the top filter and run a line into the carbs for the vapors to be sucked back into the system, is that correct? Will that gum up my carbs? Now the car sat for probably 20+ years prior to me picking it up and fixing it but it fires right up, no issues and runs "cool" and strong. Compression tests out good, valves have been adjusted to the best of my ability and there is no smoke out of the tailpipe. How concerned should I be about blowby? When I open the oil fill cap there is quite a bit of smoke and pressure coming out. I am unfamiliar with aircooled engines but I would think the piston rings are worn. Should I be thinking rebuild time? As in new pistons, cylinders, rings etc. If so, what "while you're in there" things should I start budgeting for? Please let me know your thoughts. Thank you. |
| Spoke |
Feb 17 2026, 08:21 AM
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,398 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None
I believe I should remove the top filter and run a line into the carbs for the vapors to be sucked back into the system, is that correct? Will that gum up my carbs? I've run the crankcase vent hose to both carbs on my car. Works fine sometimes. Very little oil noticed on top of the carbs. Had this for several years. When on the gas, I get no fumes in the cabin. However on long decels with carb butterflies closed, the crank gas has nowhere to go and floats out of the carb air cleaners and back into the cabin. I shut off the heat while on long decels. |
justjoel 1974 2.0l w/dual 34ICTs having blowby Feb 16 2026, 09:36 AM
Ninja Most likely oil is leaking on the exhaust/heat exc... Feb 16 2026, 11:18 AM
justjoel
Most likely oil is leaking on the exhaust/heat ex... Feb 16 2026, 12:42 PM
930cabman :wttc:
Great start to the fun of 914's and w... Feb 16 2026, 12:35 PM
justjoel Thanks for the input. I feared it'd be a rebui... Feb 16 2026, 12:38 PM
930cabman just time and money, how far and fast do you want ... Feb 16 2026, 12:48 PM
justjoel
just time and money, how far and fast do you want... Feb 16 2026, 01:21 PM
914sgofast2 Excessive blowby on an engine that has sat for a l... Feb 16 2026, 03:19 PM
930cabman
Excessive blowby on an engine that has sat for a ... Feb 16 2026, 05:45 PM
justjoel
Excessive blowby on an engine that has sat for a... Feb 17 2026, 06:39 AM
justjoel
Excessive blowby on an engine that has sat for a ... Feb 17 2026, 06:33 AM
justjoel As an update, I pulled the engine to replace the f... Jun 16 2026, 07:02 AM
Shivers
As an update, I pulled the engine to replace the ... Jun 16 2026, 09:04 AM![]() ![]() |
Lo-Fi Version | Time is now: 16th June 2026 - 11:20 AM |
