> Torsion bars
Cvrguy
post Feb 15 2026, 07:06 PM
Just pulled mine out of my '73 today as I'm replacing the suspension bushings. Both bars are slightly abraded due to the very old bushings deforming (old? I hardly had to heat the retainers in order to get them off!). Replace or not? Mine measure a little over 18mm at the shaft (18.01 and 18.25mm to be precise. The difference may be in the amount of paint on the bars). I've checked the usual sources but no luck as yet. Who might carry them? I really don't want to increase the spring rate with the 20mm ones from Pelican.
If I clean these up, are they useable? Can they be reversed? Does the minor abrasion significantly change the spring rate? Are those from the early 911 of that era an alternative?
While i'm at it, one of the adjuster screws shows signs of starting to split. Replace?Attached Image
bajafreaks
post Feb 17 2026, 04:49 PM
What is the deciding factor on when to replace the torsion bars? Looking at the pics from the original post they dont look too bad. I didnt realize they were so critical of a component.
Superhawk996
post Feb 17 2026, 05:31 PM
QUOTE(bajafreaks @ Feb 17 2026, 06:49 PM) *
Torsion bars are a highly stressed spring where the outer heat treated layer is where the highest stress is concentrated. The center of a torsion bar does virtually nothing which is why you can have hollow torsion bars.
When the outer hardened layer is compromised by corrosion, scratches, or gouging it creates a very localized stress riser where cracking will begin. Eventually the crack will propagate through the bar and the bar will fail catastrophically.
This isn’t speculation. It is an engineering reality. Having a bar fail will ruin your day.
Typical failure:
The bars in the 1st picture are scrap.
Cvrguy   Torsion bars   Feb 15 2026, 07:06 PM
Cvrguy   the adjuster screws   Feb 15 2026, 07:08 PM
Superhawk996   Replace Damage like that to torsion bars creates ...   Feb 15 2026, 07:16 PM
jim_hoyland   Where are those bushings located ? Doesn’t ring ...   Feb 15 2026, 07:40 PM
bkrantz   Where are those bushings located ? Doesn’t ring...   Feb 15 2026, 07:58 PM
barefoot   Where are those bushings located ? Doesn’t rin...   Feb 16 2026, 10:18 AM
Cvrguy   [quote name='bkrantz' post='3245327' date='Feb 15...   Feb 16 2026, 11:18 AM
jim_hoyland   Where are those bushings located ? Doesn’t rin...   Feb 16 2026, 04:28 PM
Cvrguy   [quote name='bkrantz' post='3245327' date='Feb 15...   Feb 17 2026, 04:14 PM
Cvrguy   [quote name='bkrantz' post='3245327' date='Feb 1...   Feb 17 2026, 04:16 PM
mepstein   As superhawk said you need to buy new or really go...   Feb 15 2026, 07:55 PM
Superhawk996   The torsion bars do not touch anything (other than...   Feb 17 2026, 04:38 PM
bajafreaks   What is the deciding factor on when to replace the...   Feb 17 2026, 04:49 PM
Superhawk996   What is the deciding factor on when to replace th...   Feb 17 2026, 05:31 PM
Cvrguy   [quote name='bajafreaks' post='3245576' date='Feb...   Feb 20 2026, 12:28 PM
worn   [quote name='bajafreaks' post='3245576' date='Feb...   Feb 22 2026, 09:11 PM
914werke   When attempted a trial fitting into the adjuster ...   Feb 20 2026, 12:50 PM
mepstein   When attempted a trial fitting into the adjuster...   Feb 20 2026, 01:26 PM
Cvrguy   [quote name='914werke' post='3246037' date='Feb 2...   Feb 20 2026, 03:09 PM
mepstein   [quote name='914werke' post='3246037' date='Feb ...   Feb 20 2026, 03:10 PM
Cvrguy   [quote name='914werke' post='3246037' date='Feb 2...   Feb 21 2026, 11:09 AM
PM911   The spring rating of a torsion bar is amongst othe...   Apr 3 2026, 01:05 PM
Ninja   The spring rating of a torsion bar is amongst oth...   Apr 3 2026, 03:16 PM
Superhawk996   It’s also wrong because you don’t increase a t...   Apr 3 2026, 03:27 PM
Ninja   I didn't even think about if the info was corr...   Apr 3 2026, 03:31 PM
Ninja   Got me again!   Apr 3 2026, 03:31 PM
4 User(s) are reading this topic (3 Guests and 0 Anonymous Users)
1 Members: mgarrison
- Lo-Fi Version Time is now: 3rd April 2026 - 06:26 PM
