> 76 914 crank but no start
Dustin
post Feb 16 2026, 06:16 PM
I put my car back together recently. I think everything is as it should be. Yesterday I started it and it ran for like 10 seconds and then died. I wasn't able to give it gas cause I wasn't fully seated in the car.
Today when I got in the car the generator light was on.
I started it and it ran for like 30 seconds then died. The gas pedal seemed unresponsive. Now it will crank but makes no signs of sparking. I'm only getting 7.5 volts on the + side of the coil with the ignition on.
Dustin
post Feb 19 2026, 04:56 PM
What happens if my injectors are plugged in backwards? Does it matter which way the plug is inserted?
I had been fighting with my original injection harness. I decided to use a different harness that wasn't so brittle.
My coil voltage is up. It's cranking really well. It's not even sputtering though. I don't see any reason why it wouldn't be sparking. It has fuel pressure. I don't know which way the injector plugs are supposed to go. I guess I should just flip the plugs and see what happens.
- Lo-Fi Version Time is now: 14th April 2026 - 09:41 AM
