| TRP |
Feb 23 2026, 03:02 PM
Member ![]() ![]() Group: Members Posts: 220 Joined: 2-September 23 From: Morgan Hill, CA Member No.: 27,559 Region Association: None
Hey Gang!
As I have shared, I'm having a 2056 built for my 914, bumping up from the 1.8. For this build, I upgraded to new casting 2.0L heads (stock 2.0 valve sizes), and the larger 'gowesty' throttle body. - With the larger displacement, the larger valves, and the larger throttle body? - Do I need to be concerned with the size of the intake snorkel from the 1.8 air cleaner? - If I were to consider enlarging the diameter of the air intake snorkel, do I need to consider the shape (tapered from smaller 40mm opening up too 63.5/64mm at the air box? Maybe I'm over thinking all of this and the impact would be negligible for daily driving/spirited back roads? The intake snorkel is circled in red below: ![]() Thanks, Ted |
| rfinegan |
Feb 23 2026, 04:09 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,186 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region
TRP Air Cleaner Snorkel 1.8 --> 2056 Feb 23 2026, 03:02 PM
wonkipop if you are worried about air flow to the engine pe... Feb 23 2026, 04:03 PM
rfinegan https://members.rennlist.com/demick/coldair.html Feb 23 2026, 04:09 PM
Geezer914 I eliminated my snorkel as I also installed a 50 m... Feb 23 2026, 04:20 PM
JamesJ http://www.914world.com/bbs2/index.php?showtopic=3... Feb 23 2026, 08:29 PM
914werke https://members.rennlist.com/demick/coldair.html ... Feb 23 2026, 10:18 PM
TRP Thank you all for your replies. I will noodle on t... Feb 23 2026, 10:41 PM![]() ![]() |
Lo-Fi Version | Time is now: 24th February 2026 - 02:16 AM |
