> Air Cleaner Snorkel 1.8 --> 2056, Questions, is it worth the effort?
TRP
post Feb 23 2026, 03:02 PM
Hey Gang!
As I have shared, I'm having a 2056 built for my 914, bumping up from the 1.8. For this build, I upgraded to new casting 2.0L heads (stock 2.0 valve sizes), and the larger 'gowesty' throttle body.
- With the larger displacement, the larger valves, and the larger throttle body?
- Do I need to be concerned with the size of the intake snorkel from the 1.8 air cleaner?
- If I were to consider enlarging the diameter of the air intake snorkel, do I need to consider the shape (tapered from smaller 40mm opening up too 63.5/64mm at the air box?
Maybe I'm over thinking all of this and the impact would be negligible for daily driving/spirited back roads?
The intake snorkel is circled in red below:
Thanks,
Ted
TRP
post Feb 23 2026, 10:41 PM
Thank you all for your replies. I will noodle on this a bit. I'm less worried about a cold air intake than just making sure the motor gets enough air to breath properly.
I appreciate all of the ideas.
Much appreciated,
Ted
- Lo-Fi Version Time is now: 24th February 2026 - 02:14 AM
